yunussacikk
I used c30 concrete when I first made my project, but the contractor wants c25, can I change the concrete class in all elements with a single command... do I need to change it from individual settings
"yunussacikk":18cd1lky" said:I used c30 concrete when I first made my project, but the contractor wants c25, can I change the concrete class in all elements with a single command... do I need to change it from individual settings[/quote ] Enter the properties of the material defined in the Structure Tree as C30. Select the concrete characteristic compressive strength 25.
Yes You can.You can solve each column, beam and foundation with different concrete classes if you wish."wolfman":ot8bmhvo" said:so can we just solve the foundation c20 and build the remaining floors as c25.
only when I come to the foundation and click on the static material in the properties tab, only the c25 option appears because I solved the project as c25."Ismail Hakki Feeds":2sndkzcb" said:Yes you can . If you wish, you can solve each column, beam and foundation with different concrete classes."wolfman":2sndkzcb" said:so can we just solve the foundation for c20 and build the remaining floors as c25.
