building components
Hello Mr. Ahmet, In the example, the building components are defined by taking the pose numbers from the amp metering program. If you are not using an amp program, you can use the building components defined in idecad Architecture, or you can add new building components and use them in the project with the design building components command from the tools menu. You can download the sample quantity project from the link below.
"ahmet_divan":ff99vrww" said:
I couldn't find information about build components. Is there any application or example about this?
In addition to the sample project that Ms. Hatice added, You can find information about the program in the help (F1) file of the program. Also training videos: Preparation of Building Components:
Assigning Materials to Objects:
Database transfer from AMP:
Database from AMP:
export quantity from ideCAD Architecture to AMP:
Reading ideCAD Architectural footage in AMP:
ideCAD Static to AMP quantity export:
Reading ideCAD Static quantities in AMP:
Quantity and Cost Reports:
Good work
