Hello. If you want to combine just for perspective view for rendering, select all objects on the Perspective screen and you can use Project--> Export --> 3D Block command. During this process, you need to give the block name and base point Project--> Import --> 3D Block command. You can add the block to your project using If you want to combine the project plans, separately for each floor, select the Plan and use the Project--> Copy to file command. In this process, you need to save by giving Base point and block name. In the project where you have combined the blocks, you can call the blocks you saved by using the Paste from File command in the Project menu. If you keep the Extend to axis limit option off in the Axle properties before blocking, the axis dimensions will not change according to the new contour.
