Both Tasıma
metingon
I would like to ask, the irons and texts are intertwined on the plans, how can I move them one by one, they select all of them in the move command
"metingon":24oce5x4" said:
I would like to ask you that in the plans, the irons and texts are intertwined, how can I move them one by one, select them all in the move command
Use the M key. For example, let's say you are in the pattern plan: 1. Press the M key on the keyboard. 2. Hover over a text and left mouse click 3. Move the text to the new position and click the left mouse button again.This way, you can move any existing text inside the block.
The writings on the mold plan, the irons and the lengths are very dense and confused, I wonder what is the reason for this, how can it be corrected?
"metingon":2c5v1rzn" said:
The inscriptions in the formwork plan are iron and the lengths are too concise and confused, what is the reason and how can they be corrected
The amount of confusion in the formwork plan depends on the positions of the slab calculation axes, the size of the slabs and the smoothness of the plan geometry. With the "drawing optimization" option in its properties, the program corrects the messes in the mold plan as much as it can. Before importing the mold plan, confirm that that option is selected. Apart from that, as I wrote in the previous answer, with the "M" fast move command, you can remove overlapping texts and reinforcements. you can carry.
