HakanŞahin
Administrator
The commands used for the static design building information model (bim) are given below in alphabetical order.
Click the link below to download the trial version and use the bim tools immediately.
Log in or register now.
Bim tools used for building information modeling are listed below.
| Command | Location of command in ribbon menu or toolbar | Explanation | |
| 1 |
| Concrete/Structural Inspection/Modal | Shows deformation 1.4G+1.6Q visualization dialog page. |
| Steel/Structural Inspection/Modal | |||
| Structural Inspection/Deformation | |||
| 2 |
| Concrete/Create Drawings/Steel | Draws steel 3D isometric view. |
| Steel/Create Drawings/Steel | |||
| Drawings/Create Drawings/Steel | |||
| 3 |
| Tools/Import-Export/Export | Exports to OBJ file format. |
| ideCAD logo/Export | |||
| 4 |
| View/Workplane/Target Workplane | Creates a workplane through 3 points. |
| 5 |
| Connection/Connection/4 Bolts Unstiffened End Plate Connection | Creates a 4 bolts stiffened end plate connection. |
| 6 |
| Connection/Connection | Creates a 4 bolts unstiffened end plate connection. |
| 7 |
| Connection/Connection/4 Bolts Unstiffened End Plate Connection | Creates a 8 bolts stiffened end plate connection. |
| 8 |
| Steel/Reports/Concrete | Cheks A2- A3 irregularity. |
| Concrete/Reports/Concrete | |||
| Reports/EQ Code | |||
| 9 | About ideCAD Structural | ideCAD logo/Help | It gives the program version and usage license information. |
| 10 |
| Drawings/Snap | Uses defined local coordinate system. |
| 11 |
| Right click menu in perspective view | Creates snap points on a line in a perspective image. |
| 12 |
| It is located in the hatch toolbar. | Adds lines to the hatch edges. |
| 13 |
| Analysis and Design/Define | Adds a new new section. |
| 14 |
| It is located in the hatch toolbar. | Adds a new point to hatch. |
| 15 |
| Concrete/Concrete/Stair | Adds stair area to an existing stair. |
| 16 |
| Right click menu | Adds new objects to previously created groups. |
| 17 |
| Modify/Entity Edit/Dimension | Adds/removes dimension parents. |
| 18 |
| Drawings/Edit | Generates array of entities. |
| 19 |
| Drawings/Snap | Enables advanced snap mode. |
| 20 |
| Settings/Settings | Edits commands used on the command line. |
| 21 |
| It is located in the align toolbar. | Aligns the selected entities at the bottom. |
| 22 |
| It is located in the align toolbar. | Aligns the selected entities by drawing a path. |
| 23 |
| It is located in the align toolbar. | Align the selected entities by selecting an edge of entity. |
| 24 |
| Drawings/Modify | Aligns the selected entities. |
| 25 |
| It is located in the align toolbar. | Aligns the selected entities to the left. |
| 26 |
| It is located in the align toolbar. | Aligns the selected entities to the object center. |
| 27 |
| It is located in the align toolbar. | Aligns the selected entities to the nearest point. |
| 28 |
| It is located in the align toolbar. | Aligns the selected entities to the right. |
| 29 |
| It is located in the align toolbar. | Aligns the selected entities to the top. |
| 30 |
| Concrete/Analysis/Analysis Design | Does a complete analysis and structural design. |
| Steel/Analysis/Analysis Design | |||
| Analysis and Design/Analysis/Analysis Design | |||
| Structural Inspection/Analysis/Analysis Design | |||
| 31 |
| Concrete/Structural Inspection | Shows analysis model visualization dialog page. |
| Steel/Structural Inspection | |||
| View/View | |||
| Structural Inspection/View | |||
| 32 |
| Concrete/Project Settings | Opens analysis settings. |
| Steel/Project Settings | |||
| Analysis and Design/Building | |||
| 33 |
| Concrete/Reports/Concrete/Structure Summary | Reports the settings based on the analysis. |
| Steel/Reports/Concrete/Structure Summary | |||
| 34 |
| Tools/Reference | Measures the angle. |
| Drawings/Reference | |||
| 35 |
| Coordinate Box | A enters the coordinate box. Angle is entered. |
| 36 |
| Drawings/Dimensions | Draws angle dimension. |
| 37 |
| It is located in the library toolbar. | Sets vertical angle of library automatically using underlying geometry. |
| 38 |
| Connection/Experimentals/Haunch | Creates a apex type connection. |
| 39 |
| Concrete/Create Drawings/Steel | Draws steel application plan. |
| 40 |
| It is located in the primitives toolbar. | Draws arc. |
| 41 |
| Concrete/Axis | Draws arc axis. |
| Steel/Axis | |||
| 42 |
| Concrete/Axis | Draws arc axis through 3 points. |
| Steel/Axis | |||
| 43 |
| Concrete/Concrete | Draws arc beam. |
| 44 |
| Objects/Roof/Dome | Draws arc dome. |
| 45 |
| Objects/Roof/Dome | Draws arc dome through 3 points. |
| 46 |
| Concrete/Scaffolding/Scaffolding Macro | Creates arc scaffolding. |
| 47 |
| Concrete/Concrete/Slab | Draws arc slab band. |
| 48 |
| Concrete/Concrete/Slab Edge | Draws arc slab edge. |
| 49 |
| It is located in the primitives toolbar. | Draws arc through 3 points. |
| 50 |
| It is located in the wall toolbar. | Draws arc wall. |
| 51 |
| Tools/Reference | Calculates area. |
| 52 |
| Drawings/Edit | Generates an array of entities. |
| 53 |
| Tools/Reference | Area of steel calculator. |
| 54 |
| Structural Inspection/Shell Elements/AS1 Visible | Shows shell AS1 under visualization dialog page. |
| 55 |
| Structural Inspection/Shell Elements/AS1 Visible | Shows shell AS1 upper visualization dialog page. |
| 56 |
| Structural Inspection/Shell Elements | Shows shell AS1 visible visualization dialog page. |
| 57 |
| Structural Inspection/Shell Elements/AS2 Visible | Shows shell AS2 under visualization dialog page. |
| 58 |
| Structural Inspection/Shell Elements/AS2 Visible | Shows shell AS2 upper visualization dialog page. |
| 59 |
| Structural Inspection/Shell Elements | Shows shell AS2 visible visualization dialog page. |
| 60 |
| Concrete/Create Drawings/Steel | Draws steel assembly. |
| 61 |
| Concrete/Create Drawings/Steel | Draws steel assembly with single parts. |
| 62 |
| Modify/Entity Edit | Auto label entities. |
| Tools/Tools | |||
| 63 |
| Concrete/Analysis/Analysis Design | Turns automatic analysis system generation on/off. |
| 64 |
| It is located in the hatch toolbar. | Creates hatch with closed polygons. |
| 65 |
| Concrete/Structural Inspection/Moment 3-3 | Shows frame axial force visualization dialog page. |
| Steel//Structural Inspection/Moment 3-3 | |||
| Structural Inspection/Frame Results | |||
| 66 |
| Structural Inspection/Shearwall | Shows shearwall axial force visualization dialog page. |
| 67 |
| Concrete/Axis | Draws axis. |
| Steel/Axis | |||
| 68 |
| Modify/Entity Edit/Move Axis Label | Sets the axis border. |
| 69 |
| Concrete/Create Drawings/Steel | Draws steel axis and frontal view. |
| 70 |
| It is located in the axis toolbar. | Draws an axis with an offset to the previous axis drawn. |
| 71 |
| Concrete/Axis/Axis | Opens axis settings. |
| Steel/Axis/Axis | |||
| 72 |
| View/Perspective | Changes view to axonometric. |
| 73 |
| View/Perspective | Changes view to back. |
| 74 |
| Steel/Steel | Draws steel beam. |
| 75 |
| Concrete/Concrete | Draws concrete beams. |
| 76 |
| Concrete/Design/Concrete | Display the calculation results of the beams and the selected reinforcements. |
| Steel/Design/Concrete | |||
| Analysis and Design/Concrete Design | |||
| 77 |
| Concrete/Design/Steel | Display steel beam design results. |
| Steel/Design/Steel | |||
| Analysis and Design/Steel Design | |||
| 78 |
| Concrete/Reports/Concrete | Display beam general report. |
| Steel/Reports/Concrete | |||
| 79 |
| Concrete/Create Drawings/Concrete | Prepares beam drawings. |
| Steel/Create Drawings/Concrete | |||
| Drawings/Create Drawings/Concrete | |||
| 80 |
| Structural Inspection/Input | Shows concrete design in beam live loads visualization dialog page. |
| 81 |
| Analysis and Design/Design Parameters/Concrete | Opens beam parameters. |
| 82 |
| Concrete/Concrete/Beam | Opens beam settings. |
| 83 |
| Modify/Transform | Converts beams to shearwalls. |
| 84 |
| Structural Inspection/Input/Steel | Shows steel design in beam live loads visualization dialog page. |
| 85 |
| Drawings/Primitives/NURBS | Draws bezier curve. |
| 86 |
| Drawings/Hatch | Draws bitmap hatch. |
| 87 |
| Connection/Connection | Creates a bolted flange plate connection. |
| 88 |
| Objects/Roof/Vault | Draws border vault. |
| 89 |
| View/Persoective | Changes view to bottom. |
| 90 |
| Connection/Experimentals/Multi Stiffener Plate | Creates box/tube cap plate. |
| 91 |
| Connection/Experimentals/Box-Tube Splice Connection | Creates a box/tube end plate connection. |
| 92 |
| Connection/Experimentals/Welded Connection | Creates a box/tube seating connection. |
| 93 |
| Connection/Experimentals | Creates a box/tube splice connection. |
| 94 |
| Steel/Steel | Draws steel brace. |
| 95 |
| Concrete/Design/Steel | Display steel brace design results. |
| 96 |
| Connection/Connection/Brace Corner Connection | Creates a brace center connection. |
| 97 |
| Connection/Connection | Creates a brace corner connection. |
| 98 |
| Drawings/Modify | Breaks off a certain part of the objects. |
| 99 |
| Concrete/Axis/Axis | Calculates contour polygon. |
| Modify/Entity Edit/Move Axis Label | |||
| 100 |
| Modify/Entity Edit/Stair | Cancels secondary stair deformation. |
| 101 |
| Modify/Entity Edit/Stair | Cancels stair deformations. |
| 102 |
| Concrete/Reports/Steel | Creates castellated beam design report. |
| Steel/Reports/Steel | |||
| Reports/Steel | |||
| 103 |
| It is located in the column toolbar. | Sets center aligned. |
| 104 |
| It is located in the single footing toolbar. | Sets centered single footing. |
| 105 |
| Drawings/Modify | Connects two lines with a third line. |
| 106 |
| Concrete/Axis | Changes axis drawing type. |
| Steel/Axis | |||
| 107 |
| Modify/Entity Edit/Stair | Changes baluster count. |
| Concrete/Concrete/Stair | |||
| 108 |
| Modify/Entity Edit/Column | Changes column dimensions. |
| 109 |
| Concrete/Concrete | Changes validity extent and/or moves concrete calculation line. |
| Concrete/Foundation | |||
| ModifyEntity Edit/Slab | |||
| 110 |
| It is located in the ODT door/window toolbar. | Change dio distance point. |
| 111 |
| Modify/Layers | Changes layers of selected entities. |
| 112 |
| Modify/Entity Edit/Column | Changes column jacket edge thickness. |
| 113 |
| It is located in the roof details toolbar. | Changes rafter dimensions. |
| 114 |
| It is located in the roof toolbar. | Changes roof edge properties. |
| 115 |
| Concrete/Concrete/Shearwall | Changes shearwall length. |
| 116 |
| ideCAD logo/Help | Check for updates. |
| 117 |
| Tools/Tools | Checks validity of project geometry. |
| Structural Inspection/Output | |||
| 118 |
| Drawings/Primitives | Draws circle. |
| 119 |
| Concrete/Concrete/Beam | Draws circle beam. |
| 120 |
| Concrete/Concrete/Slab Edge | Draws circle slab edge. |
| 121 |
| It is located in the wall toolbar. | Draws circle wall. |
| 122 |
| Concrete/Concrete | Draws circular columns. |
| 123 |
| Concrete/Design/Steel | Performs a 3D clash check. |
| 124 |
| Drawings/Edit | Clones (immediately copies) objects. |
| 125 | Close | ideCAD logo | Closes current project. |
| 126 |
| Right Click Menu | Closes the layer of the object. |
| 127 |
| Drawings/Primitives/NURBS | Draws closed bezier curve. |
| 128 |
| Drawings/Primitives/NURBS | Draws closed NURBS curve. |
| 129 |
| Modify/Transform/Beam to Shearwall | Transforms primitive entities to polygon column. |
| 130 |
| Modify/Transform/Beam to Shearwall | Transforms primitive entities to polygon section. |
| 131 |
| Objects/Roof | Draws a collar beam. |
| 132 |
| Concrete/Concrete | Draws rectangular column. |
| 133 |
| Steel/Steel | Draws steel column. |
| 134 |
| Concrete/Design/Concrete | Column reinforcements. |
| 135 |
| Concrete/Design/Steel | Display steel column design results. |
| 136 |
| Concrete/Reports/Concrete | Display column general report. |
| 137 |
| Concrete/Create Drawings/Steel | Draws steel column anchorage. |
| 138 |
| Concrete/Create Drawings/Concrete | Prepares column application plan. |
| 139 |
| Analysis and Design/Design Parameters/Concrete | Opens column parameters. |
| 140 |
| Concrete/Concrete/Column | Opens column settings. |
| 141 |
| Concrete/Concrete | Draws column support. |
| 142 |
| Concrete/Create Drawings/Concrete | Prepares column vertical drawings. |
| 143 |
| Concrete/Create Drawings/Concrete | Create column-beam joint cross-section. |
| 144 |
| Concrete/Reports/Concrete | Prepares column-beam joint safety report. |
| 145 |
| Connection/Experimentals | Creates a column-beam stiffened end plate connection. |
| 146 |
| Connection/Experimentals/Column-Column End Plate Splice | Creates a built up column connection. |
| 147 |
| Connection/Experimentals | Creates a column-column end plate splice connection. |
| 148 |
| Connection/Connection | Creates a column-foundation connection (Stiffened baseplate). |
| 149 |
| Concrete/Design/Concrete | Column/Shearwall punching dialog. |
| 150 |
| Analysis and Design/Define | Adds a new combination. |
| 151 |
| Tools/Quantity Report | Creates components report. |
| 152 |
| Analysis and Design/Steel Design | Display composite beam design results. |
| Concrete/Design/Steel | |||
| 153 |
| Concrete/Reports/Steel | Creates composite beam design report. |
| Reports/Steel | |||
| 154 |
| Analysis and Design/Steel Design | Display composite castellated beam design results. |
| 155 |
| Concrete/Reports/Steel | Creates composite castellated beam design report. |
| Reports/Steel | |||
| 156 |
| Steel/Steel | Draws composite slab. |
| 157 |
| Steel/Steel/Composite Slab | Draws composite solid slab. |
| 158 |
| Concrete/Reports/Concrete | Prepares compound shearwall report. |
| 159 |
| Concrete/Reports/Steel | Creates concentric braces report. |
| Reports/Steel | |||
| 160 |
| Analysis and Design/Steel Design | Select concentrically braced frame members. |
| 161 |
| Concrete/Design/Steel | Select concentrically braced frame members. |
| 162 |
| Structural Inspection/Output | Shows concrete design out all failures visualization dialog page. |
| 163 |
| Structural Inspection/Output/Concrete All Failures | Shows concrete design out axial failure visualization dialog page. |
| 164 |
| Structural Inspection/Output/Concrete All Failures | Shows concrete capacity ratio visualization dialog page. |
| 165 |
| Structural Inspection/Output/Concrete All Failures | Shows concrete design out columnt-beam joint area failure visualization dialog page. |
| 166 |
| Structural Inspection/Design/Concrete | Shows concrete design out critical shearwalls visualization dialog page. |
| 167 |
| Structural Inspection/Output/Concrete All Failures | Shows concrete design out deflection failure visualization dialog page. |
| 168 |
| Concrete/Reports/Concrete/Structure Summary | Prepares concrete Design Settings Report. |
| 169 |
| Structural Inspection/Output/Concrete All Failures | Shows concrete design out insufficient rebar area visualization dialog page. |
| 170 |
| Structural Inspection/Output/Concrete All Failures | Shows concrete design out insufficient rebar development length visualization dialog page. |
| 171 |
| Structural Inspection/Design/Concrete | Shows concrete design out longitudinal rebar percentage (%-beam endpoints) visualization dialog page. |
| 172 |
| Structural Inspection/Design/Concrete | Shows concrete design out longitudinal rebar percentage (%-beam spans) visualization dialog page. |
| 173 |
| Structural Inspection/Design/Concrete | Shows concrete design out longitudinal rebar percentage (%-columns) visualization dialog page. |
| 174 |
| Structural Inspection/Design/Concrete | Shows concrete design out longitudinal rebar percentage (%-shearwalls) visualization dialog page. |
| 175 |
| Structural Inspection/Design/Performance | Shows concrete performance analysis (brittle elements) visualization dialog page. |
| 176 |
| Structural Inspection/Design/Performance | Shows concrete performance analysis results (0) visualization dialog page. |
| 177 |
| Structural Inspection/Design/Performance | Shows concrete performance analysis results (1) visualization dialog page. |
| 178 |
| Structural Inspection/Design/Performance | Shows concrete performance analysis results (2) visualization dialog page. |
| 179 |
| Structural Inspection/Design/Performance | Shows concrete performance analysis results (3) visualization dialog page. |
| 180 |
| Structural Inspection/Design/Performance | Shows concrete performance analysis results (4) visualization dialog page. |
| 181 |
| Structural Inspection/Design/Performance | Shows concrete performance analysis results (5) visualization dialog page. |
| 182 |
| Structural Inspection/Design/Performance | Shows concrete performance analysis results (6) visualization dialog page. |
| 183 |
| Structural Inspection/Design/Performance | Shows concrete performance analysis results (7) visualization dialog page. |
| 184 |
| Structural Inspection/Output/Concrete All Failures | Shows concrete design out punching failure (foundation slabs) visualization dialog page. |
| 185 |
| Structural Inspection/Output/Concrete All Failures | Shows concrete design out punching failure (story slabs) visualization dialog page. |
| 186 |
| Structural Inspection/Output/Concrete All Failures | Shows concrete design out elements which have rebar percentage above the allowed limit visualization dialog page. |
| 187 |
| Structural Inspection/Output/Concrete All Failures | Shows concrete design out shear failures visualization dialog page. |
| 188 |
| Steel/Steel/Composite Slab | Draws concrete slab over steel beams. |
| 189 |
| Structural Inspection/Output/Concrete All Failures | Shows concrete design out torsional failure visualization dialog page. |
| 190 |
| Structural Inspection/Output/Concrete All Failures | Shows concrete design out crack failure visualization dialog page. |
| 191 |
| Concrete/Design | Display connection design results. |
| Steel/Design | |||
| 192 |
| Concrete/Reports | Creates connection design summary report. |
| Steel/Reports | |||
| Reports/Steel | |||
| 193 |
| Concrete/Design/Concrete | Displays the calculation results of the coupling beams and the selected reinforcements. |
| 194 |
| Concrete/Create Drawings/Concrete | Prepares coupling beam drawings. |
| 195 |
| Concrete/Foundation/Coupling Beam | Opens coupling beam settings. |
| 196 |
| Structural Inspection/Input/Steel | Shows steel design in electrode types visualization dialog page. |
| 197 |
| Structural Inspection/Input/Steel | Shows steel design in connection plate materials visualization dialog page. |
| 198 | Contents | ideCAD logo/Help | Opens the program's help document. |
| 199 |
| Concrete/Concrete | Draws continuous arc beams. |
| 200 |
| Concrete/Wall | Draws continuous arc walls. |
| 201 |
| Connection/Experimentals | Creates a continuous beam connection. |
| 202 |
| Concrete/Concrete/Slab Edge | Draws continuous slab edges. |
| 203 |
| Concrete/Axis/Axis | Sets contours of the drawing. |
| 204 |
| Drawings/Edit | Copies entities. |
| 205 |
| Tools/Edit | Copies contours of a drawing. |
| 206 |
| Tools/File Sharing | Copies entities to a .blk file. |
| 207 |
| It is located in the column toolbar. | Sets corner aligned column. |
| 208 |
| It is located in the single footing toolbar. | Sets corner aligned single footing. |
| 209 |
| Concrete/Foundation | Draws coupling beam. |
| 210 |
| Concrete/Reports/Concrete | Prepares coupling beam report. |
| 211 |
| Analysis and Design/Design Parameters/Concrete | Opens coupling beam parameters. |
| 212 |
| Steel/Macro | Draws Crane. |
| 213 |
| Concrete/Design/Steel | Display crane beam design results. |
| Steel/Design/Steel | Display crane beam design results. | ||
| Analysis and Design/Steel Design | Display crane beam design results. | ||
| 214 |
| Connection/Experimentals | Creates a crane connection. |
| 215 |
| Concrete/Reports/Steel | Creates crane design report. |
| Steel/Reports/Steel | Creates crane design report. | ||
| 216 |
| View/Workplane | Creates a clip plane. |
| 217 |
| Drawings/Layout Design | Creates a new layout window. |
| 218 |
| Right Click Menu | Makes the selected objects a new group. |
| 219 |
| Concrete/Concrete/Stair | Creates a new stair. |
| 220 |
| It is located in the hatch toolbar. | Creates user defined hatch from block objects. |
| 221 |
| Objects/Reinforcement | Draws a crosstie between two circles. |
| Drawings/Reinforcement | |||
| 222 |
| Tools/Import-Export/Export | Exports columns and shearwall groups to CSICOL software. |
| 223 |
| Concrete/Concrete | Draws curve beam. |
| 224 |
| Concrete/Concrete/Slab Edge | Draws curve slab edge. |
| 225 |
| Modify/Transform/Beam to Shearwall | Converts circle, arc, ellipse objects to beams. |
| 226 |
| Modify/Transform/Beam to Shearwall | Converts circle, arc, ellipse objects to shearwalls. |
| 227 |
| Concrete/Wall | Draws curve wall. |
| 228 |
| It is located in the column toolbar. | Sets default aligned. |
| 229 |
| It is located in the single footing toolbar. | Sets default single footing. |
| 230 |
| Drawings/Snap | Defines temporary coordinate system origin. |
| 231 |
| Modify/Entity Edit/Column | Defines seismic isolator. |
| It is located in the column toolbar. | |||
| It is located in the shearwall toolbar. | |||
| 232 |
| Concrete/Concrete/Stair | Deforms stair. |
| Modify/Entity Edit/Stair | |||
| 233 |
| Drawings/Edit | Delete entities. |
| 234 |
| It is located in the mirror toolbar. | Delete old entities on mirror. |
| 235 |
| It is located in the pool toolbar. | Delete primitives after pool creation. |
| 236 |
| It is located in the roof details toolbar. | Deletes roof element(s). |
| 237 |
| It is located in the slab for steels toolbar. | Deletes slab hole. |
| 238 |
| It is located in the wall toolbar. | Changes delta value. |
| It is located in the beam toolbar. | |||
| It is located in the ODT door/window toolbar. | |||
| It is located in the strip footing toolbar. | |||
| It is located in the retaining wall toolbar. | |||
| 239 |
| Drawings/Edit | Deselects all entities. |
| 240 |
| Tools/Quantity Report | Design components. |
| 241 |
| Right click menu | Closes the layer of the opened object. |
| 242 |
| View/Workplane | Display a vertical frame. |
| 243 |
| Tools/Reference | Calculates distance. |
| 244 |
| It is located in the distribute toolbar. | Distribute by drawing a path. |
| 245 |
| It is located in the distribute toolbar. | Distribute by selecting an edge of entity. |
| 246 |
| Drawings/Modify | Distrubutes the selected entities. |
| 247 |
| It is located in the distribute toolbar. | Distrubutes selected entities to the horizontally. |
| 248 |
| It is located in the distribute toolbar. | Distribute selected entities to the object center. |
| 249 |
| It is located in the distribute toolbar. | Distribute selected entities to the nearest point. |
| 250 |
| It is located in the distribute toolbar. | Distrubute selected entities to the vertically. |
| 251 |
| Drawings/Modify | Divides the objects to the desired number. |
| 252 |
| Steel/Steel/Purlin | Divides and combines on all intersections. |
| 253 |
| Steel/Steel/Purlin | Divides and combines on selected intersections. |
| 254 |
| Objects/Roof | Draws dome. |
| 255 |
| Concrete/Design/Concrete | Display the calculation results of the domes and the selected reinforcements. |
| 256 |
| Concrete/Analysis/Analysis Design | Does dome/vault analysis. |
| 257 |
| Concrete/Create Drawings/Concrete | Generates dome drawings. |
| 258 |
| Objects/Roof/Dome | Opens dome settings. |
| 259 |
| Analysis and Design/Design Parameters/Concrete | Opens dome and vault parameters. |
| 260 |
| Concrete/Reports/Concrete | Prepares dome/vault results report. |
| 261 |
| Connection/Connection | Creates a double angle connection. |
| 262 |
| Connection/Experimantals | Creates a double plate seating connection. |
| 263 |
| Steel/Macro/Truss | Draws Double Vault Truss. |
| 264 |
| Tools/Tools | Enters drafting mode. |
| 265 |
| Concrete/Concrete/Stair | Draws new stair concrete calculation line. |
| 266 |
| Right click menu | Draws similar entity of the selected one. |
| 267 |
| Steel/Steel/Brace | Draws single steel brace. |
| 268 |
| It is located in the slab for steels toolbar. | Draws slab hole. |
| 269 |
| Steel/Steel/Brace | Draws steel brace with multiple steel elements. |
| 270 |
| Connection/Mode | Draws connection in fast mode. |
| 271 |
| View/Window | Display drawing list. |
| Drawings/Window | |||
| 272 |
| View/Window | Arrange drawings in the project. |
| 273 |
| Tools/Import-Export/Import | Imports DWG DXF file formats as structure elements. |
| ideCAD logo/Import | |||
| 274 |
| Tools/Import-Export/Import | Imports DWG DXF file formats. |
| 275 |
| Tools/Import-Export/Export | Exports to DWG DXF DWF file formats. |
| 276 |
| 277 |
| Concrete/Reports | Prepares dynamic analysis report. |
| Steel/Reports | |||
| Reports/Dynamic Analysis | |||
| 278 |
| Concrete/Reports | Prepares EQ code general report. |
| Steel/Reports | |||
| 279 |
| Connection/Experimentals/Haunch | Creates a eaves haunch connection. |
| 280 |
| Concrete/Reports/Steel | Creates eccentric braces report. |
| Reports/Steel | |||
| 281 |
| It is located in the single footing toolbar. | Sets edge aligned single footing. |
| 282 |
| Concrete/Concrete | Edit concrete calculation line. |
| Modify/Entity Edit/ Slab | |||
| 283 |
| Modify/Add Load | Edits loads. |
| 284 |
| Modify/Entity Edit/Dimension | Edit label text. |
| 285 |
| It is located in the slab for steels toolbar. | Edit slab edge. |
| 286 |
| Modify/Entity Edit/Stair | Edit stair. |
| 287 |
| Concrete/Concrete/Stair | Edit stair concrete calculation line. |
| 288 |
| Modify/Entity Edit | Edit text. |
| Drawings/Text | |||
| 289 |
| Structural Inspection/Input/Concrete | Shows concrete design in element lengths visualization dialog page. |
| 290 |
| Structural Inspection/Input | Shows steel design in element lengths visualization dialog page. |
| 291 |
| Structural Inspection/Input/Concrete | Shows concrete design in element materials visualization dialog page. |
| 292 |
| Structural Inspection/Input/Concrete | Shows concrete design in element sections visualization dialog page. |
| 293 |
| Structural Inspection/Input/Steel | Shows steel design in element sections visualization dialog page. |
| 294 |
| Structural Inspection/Steel | Shows steel design in Element Materials visualization dialog page. |
| 295 |
| It is located in the section toolbar. | Draws elevation line for creating elevation. |
| 296 |
| Objects/Terrain | Draws elevation line. |
| 297 |
| Objects/Terrain | Draws elevation point. |
| 298 |
| Drawings/Primitives | Draws ellipse using corner. |
| 299 |
| Drawings/Primitives/Ellipse Corners | Draws ellipse using center and corner. |
| 300 |
| Drawings/Primitives/Ellipse Corners | Draws ellipse using midpoint and axis. |
| 301 |
| Drawings/Primitives/Ellipse Corners | Draws elliptical arc using center and corner. |
| 302 |
| Drawings/Primitives/Ellipse Corners | Draws elliptical arc using corners. |
| 303 |
| Drawings/Primitives/Ellipse Corners | Draws elliptical arc using midpoint and axis. |
| 304 |
| Connection/Connection/Single Plate Connection | Creates an end plate shear connection. |
| 305 |
| Connection/Experimentals/Seating Support Connection | Creates an end plate truss connection. |
| 306 |
| Connection/Experimentals/Seating Support Connection | Creates an end plate truss connection for box/tube. |
| 307 |
| Keyboard | Runs the command. It has functions in various command stages. |
| 308 |
| Tools/Generate | Entity from primitives. |
| 309 |
| Modify/Entity Properties | Changes entity properties. |
| 310 |
| Keyboard | Exits the found command. |
| 311 |
| Analysis and Design/Define/Load Case | Adds a new euler buckling case. |
| 312 |
| It is located in the single footing toolbar. | Exchange coordinates. |
| 313 | Exit | ideCAD logo | Quits the application. |
| 314 |
| Drawings/Modify | Separates the blocks into sub-blocks. |
| 315 |
| It is located in the steel beam toolbar. | Explodes and groups multi-element entities into single elements. |
| It is located in the steel purlin toolbar. | |||
| 316 |
| Tools/Quantity Report/Export | Exports components as a database file To AMP. |
| 317 |
| Tools/Quantity Report/Export | Exports components as a database file To OSKA. |
| 318 |
| Tools/Quantity Report/Export | Exports static quantities as a database file To AMP. |
| 319 |
| Tools/Quantity Report/Export | Exports static quantities as a database file To OSKA. |
| 320 |
| Drawings/Modify | Line extends primitive objects such as arcs to another line or arc. |
| 321 |
| Objects/Roof | Draws fascia boards. |
| 322 |
| Drawings/Modify | Activates fast move. |
| 323 |
| Settings/Settings | Edit/create fiber reinforced polymer materials. |
| 324 |
| Drawings/Modify | It connects two lines with an arc. |
| 325 |
| Tools/Tools | Finds entities based on their labels. |
| 326 |
| It is located in the hatch toolbar. | Finds hatch holes. |
| 327 |
| Right click menu | Displays an element in plan view in perspective view. |
| 328 |
| Right click menu | Displays an element in perspective view in plan view. |
| 329 |
| Connection/Experimental/Stiffened Shear Plate Connection | Creates a flange plate connection. |
| 330 |
| Steel/Macro/Truss | Draws Flat Truss. |
| 331 |
| Right click menu in perspective view | Opens fly mode. |
| 332 |
| Drawings/Text | Draws formatted text. |
| 333 |
| Concrete/Create Drawings/Concrete | Prepares formwork plan. |
| 334 |
| Concrete/Create Drawings/Concrete | Prapares foundation plan. |
| 335 |
| Drawings/Dimensions | Draws free dimension. |
| 336 |
| Drawings/Primitives | Draws freehand curve. |
| 337 |
| Concrete/Concrete/Slab | Creates a free mode slab by selecting boundary entities manually. |
| 338 |
| View/Perspective | Changes view to front. |
| 339 |
| Concrete/Analysis/Analysis Design | Determine ground motion records for mode superposition method. |
| 340 |
| Analysis and Design/Design Parameters/Concrete | Opens general concrete reinforcement parameters. |
| 341 |
| Concrete/Create Drawings/Steel | Draws steel general construction. |
| 342 |
| Concrete/Create Drawings/Steel | Draws steel general construction w/ single parts and assembly. |
| 343 |
| Tools/Generate | Generates a 2D simple drawing using current drawing. |
| 344 |
| Concrete/Analysis/Analysis Design | Generates Analysis System. |
| 345 |
| Tools/Generate | Generates vector drawing. |
| 346 |
| Reports/Foundation | Predesign Results for Geotechnic Report. |
| 347 |
| It is located in the terrain toolbar. | Get elevation from terrain. |
| 348 |
| Modify/Modify | Picks settings from entity. |
| 349 |
| Tools/Selection Groups | Gets currently selected entities. |
| 350 |
| Connection/Experimentals/Purlin Connection | Creates a girt connection. |
| 351 |
| Concrete/Analysis/Analysis Design | Ground Motion Scaling in Time Domain. |
| 352 |
| Tools/Selection Groups | Groups selected entities and selects entities based on these groups. |
| 353 |
| Steel/Macro | Creates hall. |
| 354 |
| Steel/Macro | Creates steel hand rail. |
| 355 |
| Drawings/Hatch | Draws hatch hole. |
| 356 |
| Drawings/Hatch/User Defined Hatch | Opens hatch settings. |
| 357 |
| Connection/Experimentals | Creates a haunch connection. |
| 358 |
| View/View/Solid with Edges | Changes view detail to hidden line. |
| 359 |
| View/View | Changes view detail to hidden line black && white. |
| 360 |
| Right click menu | Removes all selected entities in the 3D view. |
| 361 |
| Objects/Roof | Draws hip/valley rafters. |
| 362 |
| Objects/Terrain | Draws hole. |
| 363 |
| Keyboard | Centers the image in fly mode. |
| 364 |
| View/Workplane/Target Workplane | Creates a horizontal workplane. |
| 365 |
| Tools/Import-Export/Import | Imports IFC file. Merges file content with current project. |
| 366 |
| Tools/Import-Export/Export | Exports project to IFC. |
| 367 |
| Drawings/Text | Imports text from a text file. |
| 368 |
| Right click menu/Drawing order | Sends the selected object to the background. |
| 369 |
| Right click menu/Drawing order | Sends the selected object to the foreground. |
| 370 |
| Right click menu/Drawing order | Sends the selected object behind a certain object. |
| 371 |
| Right click menu/Drawing order | Sends the selected object in front of a certain object. |
| 372 |
| Modify/Entity Edit | Makes the selected objects beveled according to the given slope values. |
| 373 |
| Drawings/Dimensions | Draws inner dimension. |
| 374 |
| Drawings/Layout Design/Create New Layout | Inserts a layout block. |
| 375 |
| Concrete/Concrete/Stair | Changes insertion point. |
| It is located in the stair toolbar. | |||
| It is located in the library toolbar. | |||
| 376 |
| Drawings/Dimensions | Draws intersection dimension. |
| 377 |
| Drawings/Edit | Inverts current selection. |
| 378 | ideCAD Home | ideCAD logo | Opens the start page. |
| 379 |
| Drawings/Modify | Joins linear objects. |
| 380 |
| Connection/Connection | Creates a beam-beam connection (Joining plates). |
| 381 |
| Coordinate Box | L enters the coordinate box. Object length is entered. |
| 382 |
| Drawings/Dimensions | Draws label. |
| 383 |
| Modify/Entity Edit | Label entities. |
| 384 |
| Drawings/Edit | Selects last selected entities. |
| 385 |
| Objects/Roof | Draws laths. |
| 386 |
| Settings/Settings | Opens layer settings. |
| 387 |
| Drawings/Layout Design/Create New Layout | Changes settings of current layout. |
| 388 |
| View/Perspective | Changes view to left. |
| 389 |
| It is located in the column toolbar. | Sets edge left middle aligned. |
| 390 |
| Drawings/Dimensions | Draws level dimension. |
| 391 |
| Objects/Entities | Draws library. |
| Drawings/Primitives | |||
| 392 |
| Drawings/Primitives/Library | Opens library settings. |
| 393 |
| Concrete/Concrete/Slab | Draws line slab band. |
| 394 |
| Concrete/Analysis/Analysis Design | Performs a linear performance analysis of the building. |
| 395 |
| Concrete/Foundation/Raft | Draws linear raft foundation load. |
| 396 |
| Concrete/Structural Inspection/Wall | Shows live loads visualization dialog page. |
| Steel/Structural Inspection/Wall | |||
| Structural Inspection/Loads/Wall | |||
| 397 |
| Settings/Settings | Edit/create loads. |
| 398 |
| Settings/Settings | Loads settings from a file. |
| 399 |
| Tools/Edit | Local undo, undo for current mode only. |
| 400 |
| Modify/Layers | Locks/Unlocks layers. |
| 401 |
| Drawings/Modify | Blocks entities. |
| 402 |
| Tools/Edit | Make architectural file compatible with structural. |
| 403 |
| Settings/Settings | Edit/create materials. |
| 404 |
| Analysis and Design/Reinfrocement/Steel Bar Selection | Opens mesh wire settings. |
| 405 |
| Steel/Steel/Composite Slab | Draws metal slab. |
| 406 |
| Drawings/Snap | Snaps to midpoints of entities. |
| 407 |
| Drawings/Modify | Takes symmetry. |
| 408 |
| It is located in the ODT door/window toolbar. | Mirrors door/window labels. |
| 409 |
| It is located in the strip footing toolbar. | Takes symmetry with respect to the X-axis. |
| 410 |
| Concrete/Concrete/Stair | Takes symmetry with respect to the Y-axis. |
| 411 |
| Concrete/Structural Inspection | Shows deformation modal visualization dialog page. |
| Steel/Structural Inspection | Shows deformation modal visualization dialog page. | ||
| Structural Inspection/Deformation | Shows deformation modal visualization dialog page. | ||
| 412 |
| Analysis and Design/Define/Load Case | Adds a new modal analysis case. |
| 413 |
| It is located in the trusses toolbar. | Allow modify sub elements of truss. |
| 414 |
| Structural Inspection/Input/Concrete | Shows concrete design in modulus of subgrade reaction visualization dialog page. |
| 415 |
| Concrete/Structural Inspection | Shows frame moment 3-3 visualization dialog page. |
| 416 |
| Structural Inspection/Purlin | Shows purlin moment 3-3 visualization dialog page. |
| 417 |
| Analysis and Design/Steel Design | Select moment resisting frame members. |
| 418 |
| Concrete/Design/Steel | Select moment resisting frame members. |
| 419 |
| Drawings/Modify | Move. |
| 420 |
| Concrete/Axis/Axis | Moves axis label. |
| Modify/Entity Edit | |||
| 421 |
| Modify/Entity Edit/Dimension | Moves dimension texts. |
| 422 |
| It is located in the Raft Foundation toolbar. | Moves raft foundation text. |
| 423 |
| Modify/Entity Edit/Slab | Moves slab text. |
| 424 |
| Connection/Experimentals | Creates multi stiffener plates. |
| 425 |
| Connection/Experimentals/Multi Stiffener Plate | Creates horizontal multi stiffener plates. |
| 426 |
| Drawings/Primitives | Draws multiple lines. |
| 427 |
| Drawings/Snap | Snaps to nearest points of entities. |
| 428 |
| ideCAD logo | Creates a new, empty 2D drawing window. |
| 429 |
| ideCAD logo | Creates a new project. |
| 430 |
| Drawings/Layout Design/Create New Layout | Creates a new layout block using all drawing. |
| 431 |
| Drawings/Layout Design/Create New Layout | Creates a new layout block |
| 432 |
| 433 |
| 434 |
| 435 |
| Analysis and Design/Building | Adds a new material. |
| 436 |
| View/Window | Activates next window. |
| 437 |
| Analysis and Design/Steel Design | Display noncomposite castellated beam design results. |
| 438 |
| Concrete/Design/Steel | Display noncomposite castellated beam design results. |
| 439 |
| Analysis and Design/Define/Load Case | Adds a new nonlinear analysis case. |
| 440 |
| Connection/Ecperimentals/Continuous Beam Connection | Creates a notched seating connection. |
| 441 |
| Drawings/Primitives | Draws NURBS curve. |
| 442 |
| Drawings/Modify | Offset. |
| 443 |
| It is located in the section toolbar. | Finishes the current job. |
| 444 |
| ideCAD logo | Opens a previously saved project. |
| 445 |
| Drawings/Snap | Enters orthogonal drawing mode. |
| 446 |
| Drawings/Dimensions | Draws outer dimension. |
| 447 |
| Structural Inspection/Input/Concrete | Shows concrete design in overridden elements visualization dialog page. |
| 448 |
| Structural Inspection/Input/Steel | Shows steel design in overridden elements visualization dialog page. |
| 449 |
| Concrete/Structural Inspection/Wall | Shows own loads visualization dialog page. |
| 450 |
| Keyboard | Scrolls down the page in reports. Also shifts the viewpoint down in fly mode in the perspective view. |
| 451 |
| Keyboard | Scrolls the page up in reports. Also shifts the viewpoint upwards in flight mode in the perspective view. |
| 452 |
| View/Zoom | Pans the window. |
| 453 |
| Modify/Add Load | Adds shearwall lateral load. |
| 454 |
| Modify/Add Load | Adds shearwall vertical load. |
| 455 |
| Drawings/Snap | Parallel reference. |
| 456 |
| Drawings/Hatch | Draws parametric hatch. |
| 457 |
| Drawings/Edit | Paste entities. |
| 458 |
| Tools/Edit | Pastes contours. |
| 459 |
| Tools/File Sharing | Pastes entities from a .blk file. |
| 460 |
| Drawings/Primitives | Draws path primitives. |
| 461 |
| Drawings/Primitives | Draws pattern path. |
| 462 |
| Tools/Import/Export/Export | Exports To PDF. |
| 463 |
| Settings/Settings | Opens pen and color settings. |
| 464 |
| Drawings/Tools | Performs steel numbering. |
| 465 |
| Drawings/Snap | Perpendicular reference. |
| 466 |
| View/Perspective | Changes view to perspective. |
| 467 |
| Concrete/Foundation | Draws piles. |
| 468 |
| Concrete/Design | Display the calculation results of the pile and the selected reinforcements. |
| Steel/Design | |||
| 469 |
| Concrete/Reports | Prepares pile general report. |
| Steel/Reports | |||
| 470 |
| Concrete/Create Drawings/Concrete | Generates pile drawings. |
| Steel//Create Drawings/Concrete | |||
| Drawings//Create Drawings/Concrete | |||
| 471 |
| Analysis and Design/Design Parameters/Concrete | Opens pile parameters. |
| 472 |
| Concrete/Foundation/Pile | Opens pile settings. |
| 473 |
| Tools/Import-Export/Export | Saves the screen image as a bitmap file. |
| 474 |
| Objects/Terrain | Draws plateau. |
| 475 |
| ideCAD logo | Plots your drawings. |
| 476 |
| Modify/Add Load | Adds point load. |
| 477 |
| Concrete/Foundation/Raft | Draws point load. |
| 478 |
| Drawings/Edit | Creates copies of objects with rotation. |
| 479 |
| Modify/Transform/Beam to Shearwall | Transforms primitive entities to plate section. |
| 480 |
| Concrete/Concrete | Draws polygon column. |
| 481 |
| Steel/Steel/Sheeting | Draws sheeting polygon. |
| 482 |
| Objects/Entities | Draws pool. |
| 483 |
| Concrete/Analysis/Analysis Design | Performs pool analysis. |
| 484 |
| Structural Inspection/Shell Elements/Shell Results | Shows pool results visualization dialog page. |
| 485 |
| Objects/Entities | Opens pool settings. |
| 486 |
| Objects/Roof | Draws a post. |
| 487 |
| Settings/Settings | Opens preferences. |
| 488 |
| View/Window | Activates previous window. |
| 489 |
| Settings/Project Settings | Opens project settings. |
| 490 |
| Objects/Roof | Draws purlins. |
| 491 |
| Steel/Steel | Draws steel purlin. |
| 492 |
| Concrete/Design | Display steel purlin design results. |
| Steel/Design | |||
| 493 |
| Connection/Experimentals | Creates a purlin connection. |
| 494 |
| Reports/Nonlinear | Creates pushover report |
| 495 |
| Concrete/Analysis/Analysis Design | Performs pushover analysis. |
| 496 |
| Concrete/Reports/Concrete | Prepares quantity report. |
| Reports/Quantity | |||
| 497 |
| Steel/Steel/Purlin | Draws R purlin. |
| 498 |
| Drawings/Dimensions | Draws radius dimension. |
| 499 |
| Concrete/Foundation | Draws raft foundation. |
| 500 |
| Concrete/Foundation | Draws raft edge. |
| 501 |
| Concrete/Foundation/Raft Edge | Opens raft edge settings. |
| 502 |
| Concrete/Design | Display the calculation results of the raft foundation and the selected reinforcements. |
| Steel/Design | |||
| 503 |
| Concrete/Reports | Prepares raft foundation general report. |
| Steel/Reports | |||
| Reports/Foundation | |||
| 504 |
| Concrete/Reports/Concrete/Raft Foundation | Prepares raft foundation detailed general report. |
| Steel/Reports/Concrete/Raft Foundation | |||
| Reports/Foundation/Raft Foundation | |||
| 505 |
| Concrete/Foundation/Raft | Draws raft foundation hole. |
| 506 |
| Analysis and Design/Design Parameters/Concrete | Opens raft foundation parameters. |
| 507 |
| Structural Inspection/Shell Elements/Shell Results | Shows raft foundation results visualization dialog page. |
| 508 |
| Concrete/Foundation/Raft | Opens raft foundation settings. |
| 509 |
| Objects/Roof | Draws rafters. |
| 510 |
| Drawings/Primitives | Places a raster image file onto the drawing. |
| 511 |
| Drawings/Tools | Sets rebar numbering options. |
| 512 |
| Drawings/Primitives/Multiple Lines | Draws a rectangle. |
| 513 |
| It is located in the primitives toolbar. | Draws a rectangle. |
| 514 |
| It is located in the wall toolbar. | Draws 4 walls as a rectangle. |
| 515 |
| Tools/Edit | Redo. |
| 516 |
| Concrete/Concrete/Shearwalls | Draws reinforcement shearwall. |
| 517 |
| Concrete/Concrete/Slab | Removes concrete calculation line. |
| Concrete/Foundation/Raft | |||
| Modify/Entity Edit/Slab | |||
| 518 |
| Right Click Menu | Removes objects from previously created groups. |
| 519 |
| It is located in the space truss toolbar. | Removes a nodule from space truss. |
| 520 |
| It is located in the hatch toolbar. | Removes an existing point on hatch. |
| 521 |
| Concrete/Concrete/Stair | Removes stair concrete calculation line. |
| 522 |
| Tools/Render | Renders active view. |
| View/View | |||
| 523 |
| Right click menu | Repeats last command. |
| 524 |
| Modify/Entity Edit/Dimension | Resets dimension text displacements. |
| 525 |
| Modify/Entity Edit/Column | Resets column jacket edge thickness. |
| 526 |
| Settings/Settings | Resets settings. |
| 527 |
| Analysis and Design/Define/Load Case | Adds a new response spectrum case. |
| 528 |
| Analysis and Design/Define/Load Case | Adds a new response spectrum function. |
| 529 |
| Concrete/Foundation | Draws retaining walls. |
| 530 |
| Concrete/Design/Concrete | Display the calculation results of the retaining wall and the selected reinforcements. |
| 531 |
| Concrete/Reports/Concrete | Prepares retaining wall report. |
| 532 |
| Concrete/Analysis/Analysis Design | Performs retaining wall analysis. |
| 533 |
| Concrete/Create Drawings/Concrete | Prepares retaining wall drawings. |
| 534 |
| Analysis and Design/Design Parameters/Concrete | Opens retaining wall concrete settings. |
| 535 |
| Drawings/Primitives | Draws revision cloud. |
| 535 |
| Concrete/Design/Concrete | Display the calculation results of the ribbed slab and the selected reinforcements. |
| 536 |
| Concrete/Create Drawings/Concrete | Rib drawings. |
| 537 |
| Concrete/Reports/Concrete/Slab | Prepares ribbed slab general report. |
| Steel/Reports/Concrete/Slab | |||
| Reports/Slab/Slab | |||
| 538 |
| Analysis and Design/Design Parameters/Concrete | Opens ribbed-Waffle slab parameters. |
| 539 |
| View/Perspective | Changes view to right. |
| 540 |
| Connection/Experimental/Simple Base Plate | Creates a rigid on both axis base plate connection. |
| 541 |
| Connection/Experimental/Simple Base Plate | Creates a rigid on strong axis base plate connection. |
| 542 |
| Structural Inspection/Input/Concrete | Shows concrete design in rigidity reduction visualization dialog page. |
| 543 |
| Objects/Roof | Draws roof. |
| 544 |
| It is located in the roof toolbar. | Opens the roof details toolbar. |
| 545 |
| Objects/Roof | Draws roof hole. |
| 546 |
| Concrete/Creating Drawings/Steel | Draws steel roof plan. |
| Steel/Creating Drawings/Steel | |||
| Drawings/Creating Drawings/Steel | |||
| 547 |
| Objects/Roof | Draws roof plane. |
| 548 |
| It is located in the ODT door/window toolbar. | Draws roof window. |
| It is located in the roof toolbar. | |||
| 549 |
| Drawings/Modify | Rotate. |
| 550 |
| Tools/Tools | Rotates the building. |
| 551 |
| Drawings/Modify | Rotates node. |
| 552 |
| Connection/Experimental/Simple Base Plate | Creates a round plate tube base plate connection. |
| 553 |
| Tools/Import-Export/Export | Exports a SAP2000 database file. |
| 554 |
| Steel/Steel/Sagrod | Draws top sag rod connection between 2 roof purlins. |
| 555 |
| Steel/Steel/Sagrod | Draws sag rod on single purlins. |
| 556 |
| Steel/Steel | Draws sag rod on purlin group. |
| 557 |
| ideCAD logo | Saves current project. |
| 558 |
| ideCAD logo | Save current project with a new name. |
| 559 |
| ideCAD logo | Saves compresed project file. |
| 560 |
| ideCAD logo | Saves old version project file. |
| 561 |
| Settings/Settings | Saves settings to a file. |
| 562 |
| Concrete/Concrete/Stair | Saves stair. |
| 563 |
| Concrete/Creating Drawings/Steel | Creates scaffolding drawings. |
| 564 |
| Concrete/Scaffolding | Creates scaffolding. |
| 565 |
| Drawings/Modify/Scale by Reference | Scales entities. |
| 566 |
| Drawings/Modify | Scales entities by reference. |
| 567 |
| Connection/Experimentals/Seating Support Connection | Creates a seating truss connection. |
| 568 |
| Connection/Experimental/Welded Connection | Creates a seating weld connection. |
| 569 |
| Steel/Steel | Draws secondary beam. |
| 570 |
| Concrete/Design/Steel | Display secondary beam design results. |
| 571 |
| Modify/Entity Edit/Stair | Secondary stair deformation. |
| 572 |
| Analysis and Design/Define | Adds a new section. |
| 573 |
| Objects/Section | Edit and generate sections and elevations. |
| Tools/Generate | |||
| 574 |
| Drawings/Dimensions | Draws section elevation. |
| 575 |
| Objects/Section | Draws section line. |
| Drawings/Tools | |||
| 576 |
| Concrete/Reports/Concrete | Prepares seismic isolators reports. |
| Settings/Settings | |||
| 577 |
| Drawings/Edit | Selects all entitites. |
| 578 |
| Steel/Steel/Purlin | Select purlins to add analysis. |
| 579 |
| Drawings/Edit | Selects entity in all stories. |
| 580 |
| Right click menu in perspective view | Selects the created object group. |
| 581 |
| Concrete/Reports | Report selection. |
| Steel/Reports | |||
| Reports/Summary | |||
| 582 |
| Right click menu in perspective view | Selects elements with similar properties |
| 583 |
| It is located in the terrain toolbar. | Selects terrain and child entities. |
| 584 |
| Concrete/Project Settings | Use semi rigid diaphragms. |
| 585 |
| It is located in the library toolbar. | Set auto elevation. |
| 586 |
| Modify/Entity Edit/Beam-Footing | Sets console beams and footings. |
| 587 |
| It is located in the dome toolbar. | Sets dome restraints. |
| 588 |
| Modify/Entity Edit/Beam-Footing | Sets beam |
| 589 |
| Modify/Entity Properties | Sets default settings to selected entities. |
| Drawings/Modify | |||
| 590 |
| Modify/Entity Edit | Sets hatch reference point. |
| 591 |
| Drawings/Snap | Sets new local coordinate system. |
| 592 |
| Modify/Entity Edit/Pool | Set pool cantilever slab properties. |
| 593 |
| Modify/Entity Edit/Pool | Set pool surface properties. |
| 594 |
| Modify/Entity Edit/Pool | Set pool surface slope. |
| 595 |
| Modify/Entity Edit/Pool | Set pool wall properties. |
| 596 |
| Tools/Selection Groups | Sets currently selected entities. |
| 597 |
| Modify/Entity Edit/Column | Sets short columns. |
| 598 |
| Concrete/Concrete/Stair | Sets boundary conditions of stairs. |
| 599 |
| It is located in the steel column toolbar. | Sets steel element delta. |
| It is located in the steel beam toolbar. | |||
| 600 |
| Modify/Entity Edit | Sets entity trim algorithm. |
| 601 |
| Concrete/Concrete | Sets typical ribs of ribbed-waffle slabs. |
| 602 |
| It is located in the vault toolbar. | Sets vault restraints. |
| 603 |
| Concrete/Structural Inspection/Moment 3-3 | Shows frame shear 2-2 visualization dialog page. |
| Steel/Structural Inspection/Moment 3-3 | |||
| 604 |
| Concrete/Concrete | Draws shearwall. |
| 605 |
| Concrete/Design/Concrete | Display the calculation results of the shearwall and the selected reinforcements. |
| 606 |
| Concrete/Reports/Concrete | Prepares shearwall general report. |
| 607 |
| Analysis and Design/Concrete Design | Display the calculation results of the core shearwall and the selected reinforcements. |
| 608 |
| Concrete/Design/Concrete | Display the calculation results of the core shearwall and the selected reinforcements. |
| 609 |
| Concrete/Create Drawings/Concrete | Prepares shearwall drawings. |
| 610 |
| Structural Inspection/Shearwall/Axial Force | Shows shearwall moment 2-2 visualization dialog page. |
| 611 |
| Structural Inspection/Shearwall/Axial Force | Shows shearwall moment 3-3 visualization dialog page. |
| 612 |
| Analysis and Design/Design Parameters/Concrete | Opens shearwall parameters. |
| 613 |
| Structural Inspection/Shearwall/Axial Force | Shows shearwall shear 2-2 visualization dialog page. |
| 614 |
| Structural Inspection/Shearwall/Axial Force | Shows shearwall shear 3-3 visualization dialog page. |
| 615 |
| Structural Inspection/Input/Concrete | Shows concrete design in shearwall thickness visualization dialog page. |
| 616 |
| Modify/Transform/Beam to Shearwall | Converts shearwalls to beams. |
| 617 |
| Concrete/Concrete/Shearwall | Opens shearwall settings. |
| 618 |
| Steel/Steel | Draws sheeting over purlins. |
| 619 |
| Steel/Steel/Sheeting | Draws sheeting between two elements. |
| 620 |
| Structural Inspection/Input | Shows steel design in sheeting own loads visualization dialog page. |
| 621 |
| Structural Inspection/Input | Shows steel design in sheeting snow loads visualization dialog page. |
| 622 |
| Structural Inspection/Shell Elements/Shell Results | Shows shell dome/vault visualization dialog page. |
| 623 |
| Structural Inspection/Shell Elements | Shows shell solved with structure visualization dialog page. |
| 624 |
| Structural Inspection/Shell Elements/Shell Results | Shows shell slab visualization dialog page. |
| 625 |
| Structural Inspection/Shell Elements/Shell Results | Shows shell stair visualization dialog page. |
| 626 |
| View/Windows | Show coordinate box. |
| 627 |
| View/Windows | Show structure tree. |
| 628 |
| View/Windows | Show toolbars. |
| 629 |
| Modify/Entity Edit/Dimension | Shows/hides dimension text. |
| 630 |
| Modify/Layers | Show/hide entity layers. |
| 631 |
| View/View | Shows/hides nodes |
| 631 |
| Concrete/Concrete/Stair | Shows/hides railings. |
| 632 |
| Connection/Esperimentals | Creates a simple base plate connection. |
| 633 |
| Connection/Connection/Single Plate Connection | Creates a single angle connection. |
| 634 |
| Concrete/Concrete | Draws single footing. |
| 635 |
| Concrete/Design/Concrete | Display the calculation results of the single footing and the selected reinforcements. |
| 636 |
| Concrete/Reports/Concrete | Prepares single footing report. |
| 637 |
| Concrete/Create Drawings/Concrete | Prepares single footing drawings. |
| 638 |
| Analysis and Design/Design Parameters/Concrete | Opens single footing parameters. |
| 639 |
| 640 |
| Concrete/Foundation/Single Footing | Opens single footing settings. |
| 641 |
| Concrete/Create Drawings/Steel | Draws steel single part. |
| 642 |
| Connection/Connection | Creates a single plate connection. |
| 643 |
| Connection/Experimentals/Welded Connection | Creates a single plate seating connection. |
| 644 |
| Steel/Steel/Purlin | Draws single steel purlin. |
| 645 |
| Steel/Steel/Secondary Beam | Draws single secondary beam. |
| 646 |
| Concrete/Reports/Steel | Creates single-part and assembly reports. |
| Reports/Steel | |||
| 647 |
| Concrete/Concrere | Draws slab. |
| 648 |
| Concrete/Design/Concrere | Display the calculation results of the slab and the selected reinforcements. |
| 649 |
| Concrete/Reports/Concrete | Prepares slab general report. |
| Reports/Slab | |||
| 650 |
| Concrete/Analysis/Analysis Design | Does slab analysis. |
| 651 |
| Structural Inspection/Input/Concrete | Shows concrete design in slab coating visualization dialog page. |
| 652 |
| Structural Inspection/Input/Steel | Shows steel design in slab coating visualization dialog page. |
| 653 |
| Structural Inspection/Input | Shows steel design in slab total dead loads visualization dialog page. |
| 654 |
| Concrete/Reports/Concrete/Slab | Prepares slab detailed general report. |
| 655 |
| Concrete/Concrete | Draws slab edge. |
| 656 |
| Concrete/Concrete/Slab Edge | Opens slab edge settings. |
| 657 |
| Concrete/Concrete | Draws slab hole. |
| 658 |
| Structural Inspection/Input | Shows steel design in slab live loads visualization dialog page. |
| 659 |
| Concrete/Structural Inspection/Wall | Shows slab loads acting on elements (G) visualization dialog page. |
| 660 |
| Concrete/Structural Inspection/Wall | Shows slab loads acting on elements (Q) visualization dialog page. |
| 661 |
| Analysis and Design/Design Parameters/Concrete | Opens slab parameters. |
| 662 |
| Concrete/Concrete/Slab | Opens slab settings. |
| 663 |
| Concrete/Design/Concrete | Display the calculation results of the slabs with mesh wire and the selected reinforcements. |
| Analysis and Design/Design/Concrete | |||
| 664 |
| Structural Inspection//Input/Steel | Shows steel design in slab coating visualization dialog page. |
| 665 |
| Structural Inspection/Input/Steel | Shows steel design in slab thickness visualization dialog page. |
| 666 |
| Steel/Macro/Truss | Draws Sloping Flat Truss. |
| 667 |
| Steel/Macro/Truss | Draws Sloping Vault Truss. |
| 668 |
| Drawings/Snap | Snap to grid. |
| 669 |
| Drawings/Snap | Snap to nodes. |
| 670 |
| Concrete/Structural Inspection/Wall | Shows snow loads visualization dialog page. |
| 671 |
| Settings/Settings | Edit / create soil layers. |
| 672 |
| Concrete/Structural Inspection | Changes view detail to solid with edges. |
| View/View/Solid with Edges | |||
| 673 |
| View/View | Changes view detail to solid with edges. |
| 674 |
| Keyboard | Moves the cursor to horizontal, vertical, and free axis drawing positions on axes. Changes the offset in commands such as wall, column, beam, shearwall. Skips a name in object labeling. Changes the insertion point in commands such as stair, library. |
| 675 |
| Steel/Steel/Purlin | Draws space purlin. |
| 676 |
| Steel/Macro | Draws space Truss. |
| 677 |
| Concrete/Design/Steel | Display space truss design results. |
| 678 |
| Connection/Experimentals/Multi Stiffener Plate | Creates a spacer plate connection. |
| 679 |
| Connection/Connection/Joining Plates Connection | Creates a splice connection. |
| 680 |
| Concrete/Concrete | Draws stair. |
| 681 |
| Steel/Macro | Creates steel stair. |
| 682 |
| Concrete/Design/Concrete | Display the calculation results of the stair and the selected reinforcements. |
| 683 |
| Concrete/Analysis/Analysis Design | Does stair analysis. |
| 684 |
| Concrete/Create Drawings/Concrete | Generates stair drawings. |
| 685 |
| Concrete/Reports/Concrete | Prepares stair general report. |
| 686 |
| Analysis and Design/Design Parameters/Concrete | Opens stair parameters. |
| 687 |
| Concrete/Concrete/Stair | Opens stair settings. |
| 688 |
| Analysis and Design/Define/Load Case | Adds a new load case. |
| 689 |
| Connection/Experimentals/Stiffened Shear Plate Connection | Creates a stay connection. |
| 690 |
| Connection/Experimentals/Stiffened Shear Plate Connection | Craetes a stay connection (secondary beam). |
| 691 |
| 692 |
| Structural Inspection/Output | Shows steel design out all failures visualization dialog page. |
| 693 |
| Structural Inspection/Design/Steel | Shows steel design axial ratios visualization dialog page. |
| 694 |
| Structural Inspection/Output/Steel All Failures | Shows steel design out axial failure visualization dialog page. |
| 695 |
| Analysis and Design/Reinforcement | Steel bar selection. |
| 696 |
| Concrete/Reports/Steel | Creates steel beams report. |
| Reports/Steel | |||
| 697 |
| Structural Inspection/Design/Steel | Shows steel design in bending capacities (major axis) visualization dialog page. |
| 698 |
| Structural Inspection/Design/Steel | Shows steel design in bending capacities (minor axis) visualization dialog page. |
| 699 |
| Structural Inspection/Design/Steel | Shows steel design castellated beam ratios visualization dialog page. |
| 700 |
| Concrete/Reports/Steel | Creates steel columns report. |
| Steel/Reports/Steel | Creates steel columns report. | ||
| 701 |
| Steel/Steel/Columns | Draws steel column. |
| 702 |
| Structural Inspection/Design/Steel | Shows steel design composite beam ratios visualization dialog page. |
| 703 |
| Structural Inspection/Design/Steel | Shows steel design connection D/C ratios visualization dialog page. |
| 704 |
| Structural Inspection/Output/Steel All Failures | Shows steel design out connection failures visualization dialog page. |
| 705 |
| Structural Inspection/Output/Steel All Failures | Shows steel design out deflection failure visualization dialog page. |
| 706 |
| Concrete/Create Drawings/Steel | Creates steel drawings. |
| 707 |
| Steel/Macro/Hand Rail | Creates steel hand rail on arc. |
| 708 |
| Steel/Macro/Hand Rail | Creates steel hand rail on line. |
| 709 |
| Drawings/Tools | Opens steel numbering settings. |
| 710 |
| Structural Inspection/Output/Steel All Failures | Shows steel design out pmm failure visualization dialog page. |
| 711 |
| Structural Inspection/Design/Steel | Shows steel design pmm ratios visualization dialog page. |
| 712 |
| Concrete/Reports/Steel | Creates steel purlins report. |
| Reports/Steel | |||
| 713 |
| Concrete/Reports/Steel | Creates steel secondary beams report. |
| Reports/Steel | |||
| 714 |
| Structural Inspection/Design/Steel | Shows steel design in shear capacities (major axis) visualization dialog page. |
| 715 |
| Structural Inspection/Design/Steel | Shows steel design in shear capacities (Minor axis) visualization dialog page. |
| 716 |
| Structural Inspection/Output/Steel All Failures | Shows steel design out shear failure visualization dialog page. |
| 717 |
| Structural Inspection/Design/Steel | Shows steel design shear ratios (major axis) visualization dialog page. |
| 718 |
| Structural Inspection/Design/Steel | Shows steel design shear ratios (minor axis) visualization dialog page. |
| 719 |
| Steel/Steel/Purlin | Draws steel tie. |
| 720 |
| Connection/Experimentals/Stiffened Shear Plate Connection | Creates a stiffened end plate connection. |
| 721 |
| Connection/Experimentals | Creates a stiffened shear plate connection. |
| 722 |
| Objects/Reinforcement | Draws stirrup. |
| 723 |
| Settings/Project Settings | Arrange stories in the project. |
| 724 |
| Concrete/Project Settings | Copies all entities from a story to another story. |
| Tools/Edit | |||
| Drawings/Edit | |||
| 725 |
| Concrete/Reports | Prepares story forces report. |
| Steel/Reports | |||
| 726 |
| Concrete/Project Settings | Display story list. |
| Tools/Edit | |||
| View/Windows | |||
| 727 |
| Analysis and Design/Building | Opens story parameters. |
| 728 |
| Concrete/Project Settings | Arrange stories in the project. |
| 729 |
| Drawings/Modify | Stretch node. |
| 730 |
| Concrete/Foundation | Draws multiple strip footings. |
| 731 |
| Concrete/Reports/Concrete | Prepares strip footing general report. |
| Reports/Reports/Concrete | |||
| 732 |
| Concrete/Foundation/Strip | Opens strip footing settings. |
| 733 |
| Concrete/Design/Concrete | Display the calculation results of the strip foundation and the selected reinforcements. |
| 734 |
| Concrete/Create Drawings/Concrete | Prepares strip foundation drawings. |
| 735 |
| Analysis and Design/Design Parameters/Concrete | Opens strip foundation parameters. |
| 736 |
| View/Mode | Enters structural design mode. |
| 737 |
| Settings/Project Settings | Modify structural materials. |
| 738 |
| Drawings/Tools/Section Line | Draws structural section line. |
| 739 |
| Concrete/Analysis/Analysis Design | Performs risk analysis of the structure. |
| 740 |
| Concrete/Reports/Concrete | Prepares structure summary report. |
| 741 |
| Objects/Roof | Draws a strut. |
| 742 |
| Connection/Experimentals | Creates stub. |
| 743 |
| Objects/Terrain | Draws sub region. |
| 744 |
| Drawings/Window | Returns to last story window. |
| 745 |
| Connection/Connection/Single Plate Connection | Creates a T plate connection. |
| 746 |
| Structural Inspection/Input/Concrete | Shows concrete design in t-beam widths visualization dialog page. |
| 747 |
| Concrete/Reports/Concrete/Structure Summary | Prepares TBDY 2018 seismic parameters report. |
| Concrete/Reports/Concrete/Structure Summary | |||
| 748 |
| Concrete/Reports/Steel | Creates wind loads report according to TS EN 1991-1-4. |
| Concrete/Reports/Steel | |||
| 749 |
| View/Workplane | Creates a free workplane using existing objects. |
| 750 |
| Drawings/Snap | Draws tangents. |
| 751 |
| Tools/Import-Export/Export | Exports project to TEKLA software. |
| 752 |
| Objects/Terrain | Draws terrain polygon. |
| 753 |
| Objects/Terrain/Terrain Polygon | Opens terrain settings. |
| 754 |
| Drawings/Text | Draws text. |
| 755 |
| Drawings/Text/Text | Opens font settings. |
| 756 |
| Analysis and Design/Define/Load Case | Adds a new time history case. |
| 757 |
| Analysis and Design/Define/Load Case | Adds a new time history function. |
| 758 | Tip of the Day | ideCAD logo/Help | Shows tip of the day. |
| 759 |
| View/Window | Resizes the view to full screen. |
| 760 |
Log in or register now.
| 761 |
| Concrete/Concrete | Transforms a slab to a ribbed slab. |
| 762 |
| Concrete/Concrete | Transforms a slab to a waffle slab. |
| 763 |
| Settings/Settings | Opens transparent story settings dialog. |
| 764 |
| Steel/Macro/Truss | Draws Trapezoid Sloping Left Truss. |
| 765 |
| Steel/Macro/Truss | Draws Trapezoid Sloping Right Truss. |
| 766 |
| Steel/Macro/Truss | Draws Trapezoid Sloping Symmetric Truss. |
| 767 |
| Steel/Macro/Truss | Draws Trapezoid Slopping Asymmetric Truss. |
| 768 |
| Steel/Macro/Truss | Draws Trapezoid Type 1 Truss. |
| 769 |
| Steel/Macro/Truss | Draws Trapezoid Type 2 Truss. |
| 770 |
| Steel/Macro/Truss | Draws Trapezoid Vault Truss. |
| 771 |
| Modify/Add Load | Adds trapezoidal load. |
| 772 |
| Steel/Macro/Truss | Draws Triangular Asymmetric Truss. |
| 773 |
| Steel/Macro/Truss | Draws Triangular Sloping Left Truss. |
| 774 |
| Steel/Macro/Truss | Draws Triangular Sloping Right Truss. |
| 775 |
| Steel/Macro/Truss | Draws Triangular Symmetric Truss. |
| 776 |
| Drawings/Modify | Line cuts primitive objects such as arcs to another line or arc. |
| 777 |
| Modify/Entity Edit/Column | Trims column edges with an axis or beam. |
| 778 |
| Objects/Roof | Draws a trimmer. |
| 779 |
| Steel/Macro | Draws Custom Truss. |
| 780 |
| Concrete/Design/Concrete | Display truss design results. |
| 781 |
| Concrete/Reports/Steel | Creates truss report. |
| Reports/Steel | |||
| 782 |
| Connection/Experimentals/Seating Support Connection | Creates a truss connection. |
| 783 |
| Concrete/Create Drawings/Steel | Draws steel truss. |
| Steel/Create Drawings/Steel | |||
| Drawings/Create Drawings/Steel | |||
| 784 |
| Connection/Experimentals/Simple Base Plate | Creates a tube base plate connection. |
| 785 |
| Tools/Edit | Undo. |
| 786 |
| Modify/Add Load | Adds uniform area load. |
| 787 |
| Modify/Add Load | Adds unifom load. |
| 788 |
| Connection/Connection/Single Plate Connection | Creates an unstiffened seated connection. |
| 789 |
| Drawings/Layout Design/Create New Layout | Updates linked layout blocks. |
| 790 |
| It is located in the library toolbar. | Update library elevation. |
| 791 |
| It is located in the ODT door/window toolbar. | Use distance. |
| 792 |
| It is located in the ODT door/window toolbar. | Use dio as reference. |
| 793 |
| Drawings/Hatch | Draws user defined hatch. |
| 794 |
| Concrete/Structural Inspection/Wall | Shows user loads visualization dialog page. |
| 795 |
| Objects/Roof | Draws vault. |
| 796 |
| Steel/Macro/Truss | Draws vault truss. |
| 797 |
| Objects/Roof/Vault | Opens vault settings. |
| 798 |
| View/Workplane/Target Workplane | Creates a vertical workplane. |
| 799 |
| Settings/Settings | Opens view settings. |
| 800 |
| View/Window | Display view configuration options. |
| 801 |
| Concrete/Design/Concrete | Display the calculation results of the waffle slab and the selected reinforcements. |
| 802 |
| Concrete/Create Drawings/Concrete | Preapares waffle drawings. |
| 803 |
| Concrete/Reports/Concrete/Slab | Prepares waffle slab general report. |
| 804 |
| Concrete/Wall | Draws wall. |
| 805 |
| Concrete/Structural Inspection | Shows wall loads visualization dialog page. |
| Steel/Structural Inspection | |||
| Structural Inspection/Loads | |||
| 806 |
| Structural Inspection/Input | Shows concrete design in wall loads visualization dialog page. |
| 807 |
| Structural Inspection/Input/Steel | Shows steel design in wall loads visualization dialog page. |
| 808 |
| Concrete/Wall/Wall | Opens wall settings. |
| 809 |
| Concrete/Design/Steel | Define weld electrodes. |
| Analysis and Design/Design Parameters/Steel | |||
| 810 |
| Connection/Experimentals/Welded Connection | Creates a welded box/tube connection. |
| 811 |
| Connection/Experimentals | Creates Welded Connection. |
| 812 |
| Connection/Connection/Bolted Flange Plate Connection | Creates a welded flange plate connection. |
| 813 |
| Connection/Connection/Bolted Flange Plate Connection | Creates a welded web connection. |
| 814 |
| Concrete/Foundation | Draws well foundations. |
| 815 |
| Concrete/Design/Concrete | Display the calculation results of the well foundation and the selected reinforcements. |
| 816 |
| Concrete/Reports/Concrete | Preapares well foundation report. |
| Reports/Foundations | |||
| 817 |
| Concrete/Analysis/Analysis Design | Performs well foundation analysis. |
| Steel/Analysis/Analysis Design | |||
| Analysis and Design/Analysis/Analysis Design | |||
| Structural Inspection/Analysis/Analysis Design | |||
| 818 |
| Concrete/Create Drawings/Concrete | Preapares well foundation drawings. |
| 819 |
| Analysis and Design/Design Parameters/Concrete | Opens well foundation concrete settings. |
| 820 |
| Connection/Experimentals | Creates a wind connection. |
| 821 |
| Concrete/Structural Inspection/Wall | Shows wind loads visualization dialog page. |
| 822 |
| Coordinate Box | Enters the X coordinate box. X coordinate is entered. |
| 823 |
| Coordinate Box | Enters the Y coordinate box. Y coordinate is entered. |
| 824 |
| View/Zoom | Zooms the window. |
| 825 |
| View/Zoom | Zooms to the extents of the drawings. |
| 826 |
| View/Zoom | Zoom selection. |
| 827 |
| View/Zoom | Zoom into a rectangular window. |
| 828 |
| Keyboard | Zooms in. |
| 829 |
| Keyboard | Zooms out. |
