Beamless Raft Floor Drawing
tunatugay
Hello friends.. I will draw a raft slab without a beam, but the borders where I can draw the slab edge command do not appear in the architectural plan. What should I do? Thanks in advance..
Hello, It is not clear what you mean by the borders that can draw the slab edge. But you will make a foundation with amplification as the limit, you can define additional axis for amplifications. You can enter data using the coordinate box. In addition, if the projection of your superstructure elements determines your limits, you can click Settings/Visibility of Objects on Floors to mark Active floor show under Static objects in Architectural mode.
Attached is the jpg of the problem I faced with you. Thanks for your help.. Also: How do we draw the dashed lines outside the basement curtains on the foundations. Then we create a raft slab by drawing the slab edge over it... I watched it in the training video... Best regards.. carlos..
yes, the problem is exactly the same as the attachment shared by carlos.. the width of the ampatment with dashed lines in the training video is not visible to me either.. therefore I cannot define the flooring in the video to the project..
now, there are 2 types of raft foundations, beamed and non-beamed. it is formed when combined with basic flooring.. good work.. by carlos..
Hello, The red lines in the training video were created with the line command to determine the raft boundary. It has no function in raft flooring. The reason why you can't create the raft tile may be due to the closed area not being formed correctly. You add your project and we can identify where the problem is. The rafter raft foundation system, on the other hand, is the foundation system that is formed by connecting all columns to each other with continuous foundations and placing raft slabs in the spaces in between. Good work
In the project you sent, a line was drawn on 3 sides with the line command. To create a beamless raft slab, it is necessary to create a closed area with the slab edge command in architectural mode, as in the example.
Mr. Levent; Thank you for your interest, I corrected my mistake. I shared the jpg screenshot below.. 1st case. The value of 50 cm, that is, what parameters determine this value. Is it related to the raft depth; normally the number of floors*10 = the raft depth... 2nd case. axis of calculation..for example here, in cases where there is no proper geometry, what kind of way should we not follow in order to prevent the reinforcement from appearing in too many quantities..we can find out by trial method, but I am waiting for your advice on this subject...with my respects.. . . . . . . . . . . . . . . . .
1- You determine how long the ampatage distance should be, according to the condition of the building. 2-In a system like in the example project, more than one calculation axes can be defined in the same direction for different lengths, and the working distances of the calculation axes can be adjusted with the Change Rebar Calculation Axis Geometry command in the raft laying auxiliary toolbar.
good day guys. In a 9-floor building project, I receive a warning of insufficient ground safety (because it is 11) how the raft is basically ampatment, I will try that or suggest something else?
"batuhann28522":rityjqgn" said:
good day guys.I get a warning of insufficient floor safety in a 9-storey building project (because it's 11). Determine the raft foundation boundary and define the foundation by drawing from the basement columns and bulkheads from the outside as far as the ampatage distance.
"YasinTezel":34g4a6sl" said:
Hello, Determine the boundary of the raft foundation and define the foundation by drawing the slab edge from the outside at the distance of the ampathment from the basement columns and curtains.
Thank you for your attention. are we entering my radium?
I want to draw a basement screen and a raft slab in a circular area in my project, but when I draw a slab edge, the curved slab edge button is not active. how can I do that?
Hi, There is no circular raft edge command. You can create a circular raft foundation border with broken lines. You can use the Circle object in primitive objects to help. You need to model the basement curtain as broken.
Good day, I have a problem too. After making the architectural plan active in the raft foundation drawing, when I click on the slab edge button, the formwork plan becomes active again. Can you help me ?
"likosman":2lsz7pi5" said:
good day, I have a problem too. After making the architectural plan active in the raft foundation drawing, when I click the slab edge button, the formwork plan becomes active again. Can you help?
With the raft slab edge command You can create a mat foundation.Rat tile edge and tile edge are separate commands in version 8.62. Use the tile edge to draw a slab, or the mat tile edge to create a mat foundation.
