Beam reinforcements appear as zero
actombo
First of all, good evening. The reinforcements of the overhang beam k34 in my project are zero in the drawing. I deleted it, I drew it again, I analyzed it, the same problem continues. I wonder if there is something I missed? oyuqul/PROJE.rar.html]http://s5.dosya.tc/server3/oyuqul/PROJE.rar.html[/url] photo:http://i.hizliresim.com/qEzl3d.png
Hello My suggestion; K34 and K35 beams are given depending on the K axis, (what you did is not wrong, but to solve this situation) If you give the K34 Beam a new axis and define it in this new axis, it puts the reinforcements it gives as zero. Take it easy Unver ÖZCAN
"actombo":j8dq9efx" said:
First of all, good evening. In my project, the reinforcements of the overhang beam k34 appear zero in the drawing. I erased, redrawn, analyzed, the same problem persists. I wonder if there is something I missed? I would appreciate if you could help my project : [ url=http://s5.dosya.tc/server3/oyuqul/PROJE.rar.html]http://s5.dosya.tc/server3/oyuqul/PROJE.rar.html[/url] photo:http:/ /i.hizliresim.com/qEzl3d.png
Hi, K34 is equipping beam as single cantilever and program beam as cantilever. If you look at moment diagram of K34 beam, you can see that the reinforcement in the support is sufficient for the entire beam. If you do not want to reinforce the beam as cantilever, the Brackets Check "this beam is not cantilever" with the command.
Thank you Unver and Hakan. I have one more question. Should we consider the beams and floors of the overhangs as consoles?
"actombo":33f3u95q" said:
Thank you Ünver and Hakan, I have one more question. Should we consider the beams and floors of closed overhangs as consoles?
Hello, Console, at one end, is the moment that tries to pull the top of the section( We can say that it is the element that has a negative moment (negative moment) but as we go to the other end, that moment is zero. According to the negative moment, it is added to the support, the additional extension is extended to the end of the console. There is no such element as cantilever in the 3D mathematical model, we call it cantilever according to the moment diagram. (The program automatically finds the elements to be equipped as consoles by looking at the moment diaphragms.)
