Connect the continuous foundation beam to the columns in columns. If you are going to make a continuous foundation under the panel objects, make sure to catch the start and end node points of the panel. Laying with the tiling command in the areas formed in this way Enter. There should not be a column without a permanent foundation under it. That is, the columns should not press on the floor. Take it easy.
