Hi, You may have changed the Beam Right and left moment0 points. Write 0 to both values and do Analysis+Reinforced Concrete again Left moment0= The distance from the moment zero point to the left end of the beam at the beam left support. The value can be changed if desired. In the beam details, the creasing distance of the pillar is taken as the value written here. Right moment0= The distance of the moment zero point at the beam's right support to the right end of the beam. The value can be changed if desired. In the beam details, the creasing distance of the pillar is taken as the value written here.
