Re: BEAM LOAD Hello; In steel structures, you can add a trapezoidal load, as in reinforced concrete. However, if no analysis has been performed on your model, it will warn that the program loading combination is not available and you cannot enter the load. If you analyze your model once, this problem will be gone. Good work.
