Re: basic stapling problem Hello, You are getting stapling error due to floor tiles in your project. -130 cm to all floors except D06 floor in the basement floor. jeans given. In the basement floor, the upper elevations of all columns except S02 and S3 are -130 cm. Arrange by giving jeans. The elevations of the same columns on the ground floor are -130 cm. and ensure vertical continuity. In this case, stapling control will not be performed as the basement curtain and beam are connected. If it is desired to check for stapling on the columns connected to the basement curtain, in Ver 10.59 version, "Always check for stapling at the lower end (upper end)" can be checked in the Column settings / Staple reinforcement tab. Good work
