Yes, I know it can be seen here, but the values in the example in the attached picture did not make much sense to me."Ismail Hakki Feeds":2pvhhrwb" said:Clicking the Analysis and Design View section of the Menu, the Deformation Modal icon opens the visualization dialog. From here, select Modal1,Moda2, Modal3 or Modal4.
So how should we reach these final values. When calculating the uins related to Chapter 6, modal displacements of each mode are requested, how can we reach these values?"Admin":31ycez0c" said:Modal nodal displacements show the self-deformation shape of the building in the relevant vibration modes. The amplitude values have no physical meaning on their own. Their shape and contribution to each other are important. However, these displacements combined with the response spectrum function their final values are meaningful.
Yes, modal displacements are illogical as you said. The displacement values determined in the modal analysis cannot be interpreted as the actual displacement values. The reason is that the spectrum has not yet been included in the modal analysis. Since there is no spectrum at this stage, the final value of the displacement cannot be determined. So; In modal analysis, the opposite side of the equation of motion is 0. In this way, period and angular frequency values are determined. These values are also relative. In other words, there are 2 outputs with physical meaning: Period and Angular frequency. The displacements determined from the modal analysis are an indication of the relative displacement in your design. In order to determine the true value of the displacement, Response Pectoral Analysis is performed using the spectrum given in the regulation after the modal analysis. IdeCAD also performs the response spectrum analysis after the modal analysis, calculates these magnitudes for each mode and stores the combined modal magnitudes in memory by performing full-square merging, and prints these values in the program interface and reports."MrtGrsl":294vrvcj" said:Yes, I am aware that it can be seen here, but the values in the example in the attached picture did not make much sense to me. 400mm displacement."Ismail Hakki Feeds":294vrvcj" said:Click on the Deformation Modal icon in the Analysis and Design Display section of the menu, and the visualization dialog opens. You can select Modal1,Moda2,Modal3 or Modal4 from here, if you want to see the displacement of which mode in which modal account, you can see the displacement on the basis of node points.
Your question was asked and answered in a foreign forum. link address"MrtGrsl":1eky80rc" said:It seems logical to me now, but I hope we can talk to the municipality team tomorrow and resolve the issue. Thanks for the information. Good work.
"Ismail Hakki Besler":3c3htsvp" said:Thank you İsmail."MrtGrsl":3c3htsvp" said:It makes sense to me now, but I hope we will talk to the municipality team tomorrow and resolve the issue. Thanks for the information. Your same question has been asked and answered in a forum. Question Answer Forum link addressYou do not have permission to view link Log in or register now.
