auxiliary lines
Enigma21
Tekla Struc. Is there any idecad like auxiliary lines found? For example, finding the midpoint of an interval or dividing an interval into 3 equal parts...
Hello there; You can create capture points by entering the distance from the beginning and the end in any number you want with the commands to create special capture points on the object and create special capture points on the line in the right click menu. You can use the commands such as midpoint, closest point in the upper toolbar of the program by activating them. Good work.
