What kind of project you want to define diaphragm manually. Normally ideCAD define the diaphragm automatically.ammer":1lv54v42 said:Hi...
Could anyone guide me, how to control the diaphragm manually??
Regards
You can model the building as real. And control the diaphragms. You chek the analysis option as response spectrum and the masses is not on the rigidity center of stories. İf you want distribute the masses whole story and control the diaphragm design please use semi rigid option also.ammer":29llfjsr said:Thanks for reply, I have a long building, consist of 3 parts, that`s mean, I have 2 expansion joints. Actually, I want to study them, as seismic joints, since the parts of building are too close (about 3cm width of exp. joint), the building is 10 stories high. I wanna check the real seismic behavior and the possibility of pounding between these parts, just to see if we neet to increase the width of (exp. or seismic) joints.
Regards.
