Today, I solved a project whose walls were placed in ide5architecture by saying take the wall loads from idearchitecture in ide6. Normally, at idestatic 5, the door and window gaps fell and found the wall load (0.402tf/m wall load, 1.3tf/m3 unit wall weight) on ide6 0.65 I saw that it was tf/m, so what I understand is that it automatically solved the wall on it as 19cm youtong and there was no case of any door window gap falling. What I want to ask is when will full architectural integration be provided in ide6? Will it come with idearchitecture6? Also, the part that was discarded as a place in idemimari was seen as a floor by ide 6 and naturally I got a warning that deflection and floor height do not save I wish you a good work
