any of the floors have an alpha of less than 0.7
frht
friends, while getting a report in the project, there is an alpha less than 0.7 on any of the floors, it gives an error, how can I fix it ???? link:
Thank you in advance.
Fix geometry control errors in the project. (especially non-overlapping columns = vertical discontinuity) Then increase the column dimensions. At least make the narrow sides 30 cm. (as much as you can and on all floors) Check some beam loads (may be missing) Enter stairs and model together. Try to connect the objects at the nodes. (Check the p2 s2 column connection) You can make the p2-p16-p17 curtains in the basement as a single curtain and give space inside the curtain.
IT MAY GIVE THIS PROBLEM BECAUSE THE OBJECTS ARE NOT CONNECTED AT NODTS..TRY AGAIN BY FIXING THE DATA INPUT..COLUMNS AND BEAMS ARE NOT CONNECTED TO THE AXLE LARD..
