Hello there; First of all, you modeled the lovers wrong. They were overlapping. You can decide which one is more suitable for you to use by examining the minstrel menu in the program and trying different placement options. Assemble between the columns and beams using the welded joint for the box/pipe profiles. Analysis could not be performed because the combinations were not complete. I made these changes. Analysis can be done now, but I don't get an error like you mentioned. By the way, since you are using a box profile, you need to arrange the elasticity module of fe 37 under the materials as 21000000tf/m2 every time.
