Angle axle, angle beam
gazidemir
hello friends, in my project, the axis in the architecture is angled, the column beam on the axis is also angled. I can't adjust their eccentricity, I would appreciate it if you could help (the project is attached.. if you change the project extension to .ide8demo, the project will open.. thanks
Hello, columns have been created in the project you have uploaded. When the columns are held from the corner points, the offset can be adjusted with the help of the space key on the keyboard. If you want to draw a parallel beam based on an inclined axis; You can use the parallel reference command. Good work
