Hi Enter the properties of the beams listed in the Geometry control. In the Static/Reinforced Concrete settings, disable the "Defined section parameters" option.
Erase the staircase you drew outside the building in the basement. or set the support conditions to a structure-independent solution. When you analyze, the coordinate of the problematic joint point is given. You can identify the problem by examining this point.
