Adding Stair Space
fatihkaya17
I cannot adjust the elevations of the stair areas I have added. After defining the ladder from the route drawing, when I say create a ladder area and then add an area, it does not allow to adjust the elevations. So I can't make the drawn ladder one piece. What I want to do is at the top of the stairs
While determining the stair areas with the route command, the direction of drawing the exit lines is important in terms of determining the exit direction of the stair. In the project you added, the output lines are drawn in the opposite direction in the parts named as the 1st area and the 2nd area in the picture. If it is drawn according to the number sequence shown in the picture, a ladder can be created. You can also watch the following videos about the definition of stairs.
Re: ANGLE PANEL Since there is a ramp in the project, I presented such a solution, I don't know how accurate it is. but how can I make it curve from the bottom when defining the panel separating the ramp? I had to post a picture because there is a 4mb limit. Thank you
When looking at my drawing, I looked at a different place and you created the ramp, but when it comes to the part with stairs, it was done to see if the vehicles would return from there or just pass the municipality approval. After making the analysis, if you adjust the slope with two-dimensional drawing possibilities, it will be okay. I don't know if you have given a load for the vehicle load here.
Thanks for your time, I bought q= 5kn/m because the ramp there is a disabled ramp, I don't think it will cause much trouble.
