Dear Madam; Where there is a linear load in the figure, there is a wall load. My question is, I can apply some of the load to the right slab and some to the left slab as a linear load, but should I calculate the part of the load passing through the beam and load it on the beam as much as that weight, or does the linear load that passes through in this way directly affect both the beam and both floors? If this is the case, if we draw the wall loads as linear loads on the beams and floors (as in the figure), will all beams and floors have their own length loads? I am waiting for your help.. I hope I have been able to explain.. Thank you..
