P petek New Member Mar 2, 2012 #1 I couldn't find the option to add object, which is described as under the layout menu in the help. If you help.
L Levent Özpak New Member Mar 2, 2012 #2 "honeycomb":2en4r1c7" said: I couldn't find the option to add an object, which is explained under the layout menu in the help. If you can help. Click to expand... Hello, the Add Object command has been removed because it is not functional and not used. Good work
