About the hood zone on the curtains
mhmt_ali
In my project, I made a 1330/40 curtain solution. However, it did not create a head area on the curtain in column application and panel vertical expansions. Can you explain the solution to this? II studies.
3.6.2.1: It says that curtain end zones will be created at both ends of the walls with Hw / lw > 2.0. i.e. if its height is more than 2 times the plan length, the header is mandatory. if not, you can manually create the curtain tie from the curtain settings.
