About the curtain wall and 3D floor plan
serkan zorlu
hello, I would like to consult you with a question that has been on my mind for a long time;
There is a very nice curtain wall work of this work. Is it possible to share a similar work or a video of this work, if any.. how long will it take to estimate this and a similar work? Although it seems impossible in my world to make the details in this work, it was obviously made with ideCAD and put here.. people are very enthusiastic when they see them.. can a similar project be added in order not to lose our enthusiasm? In my other question, there are programs that make 3d floor plans. It came across in the forum again. Just as high quality as the programs used for making floor plans, there is an example of a floor plan on the site. are we there was a shaded layout plan in the layout design video again, I liked it, but I tried it. I would like to express my endless thanks to my dear friends who are interested in the ideCAD family.
Hello Mr. Serkan, The project in the link you sent belongs to our 6.2 version beta version, it has been shared to show the new possibilities in the program. You can access the curtain wall, interior and other rendering scenes from the link below.
For floor plan rendering, set the angle of the sun to the vertical in the render settings to a smaller value like 4-5, in this way, you enable the objects to cast a little shadow on each other. Also, you should choose a value close to 0 for the brightness value and brightness strength of the materials you use. You can also disable the reflection feature on objects. If you want to see the window openings in the render, define a roof with a horizontal slope close to 0 and enter the roof elevation with the horizontal axis elevation value. (eg 1.2 m) Click the cut with roof command in the Tools menu, select the new trim command and leave the top trim option active in the dialog that opens. Select the roof, click the right button and then select the other elements you want to cut such as walls-windows and exit the command by saying OK. After the process, select the framework and right-click to close the object layer. Make your workplane top view, click the render command and you can render the Kayplan. For a black and white view, change the default view on the perspective screen to the view you want and right-click on the perspective screen again to switch to the black and white hidden line mode. You can obtain data from the preview image by making a print screen. In layout design, right click on the plan working plane and set a new layout. In the same way, define the blocks you want to add to the layout by right-clicking on the plan and selecting one of the options such as layout block, rectangle-circle. Just like when you switch between floors, select the layout and add the blocks. The layout design is done in the ideCAD Architectural program. If you have work related to these processes, if you share your project, we can guide you about your work. Take it easy, good work...
