About Import
mhtcn
I am a 4th year civil engineer student. I have an architectural project in hand, I will import it to idecad statics, but I will import which floor to which floor, how will I enter the wall loads, if there is a brother or sister among you who knows, I would be very grateful if they could help. Thank you to those who helped.
Hello, Create a blank drawing with the "New 2D Window" command in the Project menu. After deleting the drawings such as furnishing that are not required in the DWG drawing, import them to this page. Block the architectural plan of each floor separately. You will use the architectural plan of an upper floor when creating the static formwork plan. For example, the 1st normal floor architectural plan will be used to create the ground floor ceiling formwork plan and for wall loads. You can work by copying the blocks to the corresponding floor plans.
