About Cork Flooring
isbandam
Hello there. In terms of the operation of the program in cork flooring systems; --Do you mind if we turn the outer edges of the building with beams and enter data without defining the header on the interior columns? (in version 7) --Do we need to change the "clear span for thickness control" value to the maximum span between the columns.(Program control defined account eg account axis long=1266 cm min hf=43 cm ) Good work.
If you have not used beams anywhere, you do not need to define a header. No, if you have used beams, you must define a header for the punch verification. You should do as you say about the thickness control issue. You should set it for the maximum opening.
