8.5 Update
serdagi
Hello, I learned from the forum that the new version will be presented with the 2016 Istanbul construction fair. Not everyone can attend the fair, it would be great if the new version is shared. good work....
Re: New Version
"serdagi":to7ijyrq" said:
Hi, I learned from the forum that the new version will be presented with the Istanbul construction fair in 2016. Not everyone can attend the fair, it would be great if the new version is shared. good work... .
It will be shared with users next week, right after the fair presentation.
Re: New Version 8.5 ideCAD Steel and Reinforced Concrete Update from 8.103 to 8.5 8.500 You can download the update from the link below: This version has been removed from access. Click
for newer versions. What's New in 8.5 According to 8.103: 1- Element design with TS EN 1993-1-1 Euro code 2- Wind loads calculation with TS EN 1991-1-4 Euro code 3- Published in the Official Gazette Design of Elements and Steel Joints with the New Steel Regulation 2016 4- Scaffolding Macro 5- Cover joint for Box/Pipe profiles 6- Stiffened butt plate joint for weak direction 7- Butt plate truss joint 8- Front plate truss joint for Box/Pipe profiles 9 - Seating truss junction 10- Crane joint 11- Bottom plates can be angled in ridge joint 12- Separate layer for secondary steel beams 13- Console element combination has been made more suitable for cranes. 14- Work was carried out to create plan drawings, point details, facade drawings in steel drawings, and to reduce interference with simplification in steel drawings. 15- Steel column-single foundation drawings 16- Length, weight, etc. given in the layout table in the steel drawings. displaying the units of the values 17- Self load of the composite slab was not transferred to the system. Transferring. 18- Since metal floors do not exhibit rigid diaphragm behavior, the program does not create a rigid diaphragm for them. 19- Ability to Turn on/Off purlins in 3D Filter REINFORCED CONCRETE POSSIBILITY AND IMPROVEMENTS 20- Modeling of rafter raft foundations according to finite elements together with beam, plate and superstructure 21- Making raft foundation by defining a continuous foundation only from the outer frame 22- Continuous Monitoring moment shear force diagrams of foundations without visualization 23- Modeling of continuous foundations as T beams 24- Beam-beam, continuous foundation-continuous foundation, panel-beam etc. In divisions, the element division algorithm has been improved according to the carrier-bearing element relationship. 25- General improvements have been made regarding column-foundation beam connections for continuous foundations. 26- In raft foundations, the flooring under the columns seemed to be cut visually. Now it looks whole. 27- Giving the controls in the retaining wall reinforced concrete dialog 28- In the column reinforced concrete dialog, reinforcement deficiencies were not shown in red, they are now displayed. According to version 29-7, rib beams were not shown in the cross section of the formwork plan. It is now showing. 30- In the Risky Building Analysis, polygon column dimensions appeared as rectangles in the critical Floor column limit values report. Adjustments have been made for circle and polygon column dimensions. 31- Beamed raft basically, negative printing of G and Q was perceived as negative stress in Reports. Absolute value is now printed. 32- When a rigid diaphragm is detected, a warning is given as Rigid Diaphragm-1 Rigid Diaphragm-2 instead of RD1 RD2. 33- The Risky Building Analysis command has been added to the Analysis menu. 34- Ability to choose gradient background color 35- ideCAD Wrep 8 36- 3D Printer model output capability has been improved
Re: New Version 8.5 good work, I wanted to share the project I revised in raw form, it's good, I will share it when it's finished. Thanks to everyone who contributed in advance.
Re: New Version 8.5 Hello Mr. Güray; The ability to give the angle you mentioned about the joint has been added. Please try by entering values such as 30, 60 in b1, b2 parameters in the stiffeners tab. D parameters are not for angling. Good work. Sent from my E6553 using Tapatalk
Güray Bey and Nurgül Hanım were able to make the lower rigid element in the - direction, but I saw something, how can I fix it. The beam rib element protrudes too far.
good day, when I install the ide build update, I get the error that the mfc140.dll file could not be found, I removed both the old and the update, I reinstalled it, but I encountered the same error, what should I pay attention to when updating, good work
Hello there; For editing, Mr. İbrahim, you need to edit with the b coefficient in the reinforcement section. The default values will be corrected in the next intermediate version. In case of missing .dll files during installation, you can download them by searching the internet. You need to copy it to the folder where idecad is installed on your computer. Good work.
"bha":36h442ej" said:
good day when I install the ide build update, I get the error that the mfc140.dll file could not be found, I uninstalled both the old and the update, I reinstalled it, but I encountered the same error, what should I pay attention to when updating, good work
The installation of the Microsoft plug-in may have failed, you can download and install the plug-in from the link below. Visual C++ Redistributable Package for Visual Studio 2015, x86 and x64 must be installed...
Hello, thanks for the update, I wish everyone good luck. However, I have installed both static and architectural updates. After opening both programs, it crashes and closes as in the attached picture. good work...
Hello, thanks for the answer, but it still doesn't work, also why do you need to press the button on every boot? I'm going back to the old version, it would be appreciated if you could share the full install file instead of the update for 8.5. good work
"serdagi":2mt08cbd" said:
Hi thanks for the answer but it still doesn't work, also why do I need to press the key on every boot. I'm going back to the old version, I'd be glad if you could share the full installation file for 8.5 instead of the update. good work
Program If it is opened with ctrl + shift for once when it is first installed, this will not be a problem. You do not need to do it every time. Uninstall the programs from your computer, install the full version 8.103, install the 8.500 update on it. If you want, friends can investigate your problem with remote access on Monday. This is a general situation. not.
Crtl Opening with + shift resets the settings. Apply once. If your problem is not resolved, call our Bursa office on Monday, we will connect to your computer with remote access and see what the problem is together.
"serdagi":2zryb8kx" said:
Hi, thanks for the update, I wish everyone good luck. But I have installed both static and architectural updates, after opening both programs, it crashes and closes as in the attached picture. good work...
[b ]Is there another steel user having this problem?[/b]
