4.9.1 Calculation of Effective Relative Floor Offsets
ottomancagatay
I want to choose the infill wall flexible connection option in the project and apply it on the construction site, do we have to experiment for this? 1.4 Experimental design The tests of special building components that may be needed in the implementation of this Regulation will be carried out by a certification body accredited according to TS EN ISO / IEC 17025 standard or accredited according to TS EN ISO / IEC 17065 standard, unless certification is required within the scope of its own technical regulations. In cases where sufficient computational models are not available, a large number of similar components are used, or in experimental studies to verify the assumptions used in the design, the principles given in TS EN 1990 Annex D or equivalent international methods will be taken into account.
"ottomancagatay":2szytmwe" said:
I want to choose the infill wall flexible connection option in the project and apply it on the construction site, do we need to do experiments for this? unless necessary, it will be done by a certification body accredited according to the TS EN ISO / IEC 17025 standard or accredited according to the TS EN ISO / IEC 17065 standard. The principles given in Annex D of 1990 or equivalent international methods will be taken into account.
Hello, If you are not going to use the detail given in the regulation and use another detail, you may need to prove the compatibility of this detail by experiment. Otherwise, there is no obligation to test. Best regards. iPhone using Tapatalk sent via
