Levent Özpak
Active Member
Panel at different elevations The simplest solution for the objects to work together is to place a column at the junction of the panels."proisa":offwzb6y" said:How to get rid of the problem in the picture? Floor height 410cm Finite element width 50cm on the left side, this does not join. On the right side, even though I reduced the finite element width to 10cm, it still does not join.
The analysis time is prolonged when the finite element width is made 5 cm normal."proisa":offwzb6y" said:Reducing the finite element width to 5cm, it was solved, but the analysis took 9 minutes at full rigidity.
