I want a single opening window with dimensions of 140*140. In the example there is always a divider in the middle, the plain one is needed, there will be only double windows and there will be a single opening wing.
I looked at the folder where the program is installed for ODT, there is an application shortcut, but it gives a warning and does not work as in the picture
Hello, you are getting an error like this because Windows updates are not installed on your computer. If you download the missing "Microsoft Visual C++ Redistributable" packages from your computer and install them on your computer, the problem will be solved. Good work.
