Uncheck Multiple stirrup design in Column Settings/Static Reinforced Concrete tab. studies"actombo":2bqalstg" said:hello, is it possible to design columns without double stirrups, good work
thank you Mr. Levent. I want to ask you one more question. I started a new project. My drawing is not visible in perspective. What could be the reason?"Levent Özpak":2wjt1sz8" said:In the Column Settings/Static Reinforced Concrete tab, uncheck the Multiple stirrup design line. Good work"actombo":2wjt1sz8" said:hi, is it possible to design columns without double stirrups? Good work
If you have imported dwg file into the project, the imported drawing may be in a coordinate far from the origin point. In this case, move the lower left corner of the drawing to the origin point. If the problem is not resolved, add the project file. Good work"actombo":1yfmaa8c" said:thanks Mr. Levent. I want to ask you one more question. I started a new project. My drawing is not visible in perspective. What could be the reason?
