Zoom Limit Error
NYILMAZ
In the attached file (I sent the block file), double click or zoom limits command does not work. There is no problem on other floors or other 2D drawings in the project. The problem is in this drawing. Even though I tried copying it on another page or making a block and opening it in a new project, the result is the same. I couldn't find where it came from. Good luck with. NY
"NYILMAZ":1rthiwuq" said:
Double click or zoom limits command does not work in the attached file (I sent a block file). There is no problem in the project on other floors or other 2D drawings. The problem is in this drawing. Copying it on another page or making a block in a new project Even though I opened it and tried it, the result is the same. I couldn't find the source. Good luck.
Hello Nedim, The problem seems to have occurred in the blocked root sprout details on the left and right base. You can solve the problem as follows. 1. Select the basic sprout details with shift+window (not selected when clicked) smash with object smash 2. Select application and basic sprout details in window form 3. Click Edit/Invert selection 4. Hit Delete 5. Problem will be solved when zooming borders 6. If you want "make block" You can block the basic sprout details again with . Also I am attaching the file as blk to the message... Good work
I guessed that the problem was caused by the root shoots when it was not selected by clicking as you mentioned. No problem for my project. I sent it to see if it could be a general problem. Thank you, good work.
