zk problem in ground floor S03 column
erdigoksu
there is a zk problem in the s03 column of the ground floor in my project, how can I solve it? d/0B4bbnN ... sp=sharing[/url]
Hello, Vis/Vik ratios are above 070 in your project. Therefore, the Zk (weak column) warning in the S3 column is not a problem in terms of the Regulation. You can review TDY 2007 article 3.3.5 and article 3.3.6 on the subject. If you still say "I don't want the S3 column to be a weak column"; Enlarging the short side size of the column can prevent weak column formation. Note: The initial floor width of the D02 ribbed floor on the 3rd floor ceiling is 190 cm. and this part was intended to be modeled as if it were a plaque. Bending reinforcement is not calculated for hollow floor slabs, distribution reinforcement is placed. Therefore, your model is not suitable for hollow data entry. I suggest that you divide the floor with a beam from the appropriate place and define the 165cm part as slab floor.
"Levent Özpak":18wwrfpe" said:
Hi, Vis/Vik ratios in your project are over 070. Therefore, the Zk (weak column) warning in the S3 column is not a problem in terms of the Regulation. TDY 2007 article 3.3.5 and article 3.3 on the subject You can review .6. If you still say "I don't want the S3 column to be a weak column", increasing the short side size of the column may prevent weak column formation. Note: The initial slab width of the D02 ribbed slab on the 3rd floor ceiling is given as 190 cm and this part looks like a slab slab. Bending reinforcement is not calculated in hollow floor slabs, distribution reinforcement is added. Therefore, your model is not suitable for hollow block data entry. I recommend that you divide the slab with a beam from the appropriate place and define 165 cm as slab slab. .) Good work
now I get the error "Increase system rigidity", I would be very happy if you could take a look at the project
"Levent Özpak":2kp4tdee" said:
"erdigoksu":2kp4tdee" said:
now I get the error "Increase system rigidity" If you could take a look at the project, I would be very happy
I do not encounter such a warning when I analyze the last project you added and get a report .
sorry I'm sending the new version now
