HakanŞahin
Administrator
What are your views on the implementation of tdy 3.4.3.1b in 6 versions? In ideCAD 6 version, the most important difference in beam expansions compared to 5 is the tdy 3.4.3.1 control, and according to this control, the bends of the beams inside the column are drawn shorter than 5. In addition, if the condition cannot be met, the program warns the user. For columns with a width of 25 cm, this condition is often unsatisfactory depending on the size of the reinforcement used. For example: If a 50 cm high beam ends with a 30 cm column supported by a column of 30 cm: bend length of 12 gauge reinforcement = 23 cm bend length of 14 reinforcement = 32 cm  The curve length of the reinforcement = 40 cm  is drawn. . In version 5, these three values are 44cm. What are your views? Do you apply your drawings according to tdy 3.4.3.1 in your projects or do you use it like version 5? I wish everyone a good day...
