Your questions about performance analysis
Zumre
I guess there is no linear performance analysis in the new update because I get idecad has stopped working error in every analysis.
Re: Performance analysis We have a great need for performance right now, yes "To do it with Idecad right now". I want to ask something. Also, whether the Nv effect is taken into account in shear tilting moments is in the program. Do you mean you can catch the results and use them if you want? It's wrong, but it's up to you, do you say if you want to do it wrong? (The reason why I write this way is that I have made a lot of comparisons about this subject before, I made a solution with both programs under the same system and loads, and I shared it here, it was said that the solution made by the program was not correct, with İde. will it be right when you do it).. I hope you don't ban. Good work
"myıldız25":s21dcx9m" said:
I would like to ask something. Also, whether the Nv effect is taken into account in the shear overturning moments means that you can catch the results in the program and use it if you want? It's wrong but it's up to you. Do you think you can do it wrong if you want? (The reason why I write this way is that I have made a lot of comparisons about this subject before, I made a solution under the same system and loads with both programs and I shared it here, I was told that the solution made by the program x will be correct when I do it with IDE) .. I hope you won't be banned. Good work
2018 Regulations never allow you to choose this option and we do not recommend you to choose it. Therefore, the solution made by choosing this option is not in accordance with the regulation. Regulations are not texts in which ordinary rules are written. You can't guess it because this is my interpretation This is our opinion. If you think that this version of the regulation is wrong, we offer you flexibility. We are doing this by putting this option. We're not telling you to do it wrong if you want. On the contrary, we say calmly, do not do wrong. If you insist on the wrong thing, we say go ahead. In your words: Using this option is not in compliance with earthquake regulations, but it is up to you.
Re: PERFORMANCE ANALYSIS
In the first half of May Linear Performance Analysis (Article 15.5)[ /u] can be updated.
We said it. It may take a week or two.
You always give the next date. With the information we received from you 2 months ago, we were saying to our customers that "an update will be released in 1 month". You said April, then you said the first week of May, and now you say it may be delayed again. Can you give a clearer date when this update will be released?
PERFORMANCE ANALYSIS ABOUT THE LOCKED TOPIC. Hello, Can you inform us about the current situation regarding performance analysis? We kept our customers waiting by saying the end of April, the beginning of May, and the middle of May, now we are stuck. If you say something good or bad, we will take our position accordingly after this time.
ideCAD 7 performance Hello. Is there any harm in analyzing the performance analysis of the project with the wrong ground safety after changing the ground values, with the following settings? This way, there is no problem in the structure
PERFORMANCE ANALYSIS ( HAS BEEN 6 MONTHS ) IT HAS BEEN 6 MONTHS. ALL OUR WORK IS PERFORMANCE AND STRENGTHENING. I'M NOT SAYING ANYTHING OTHER.
Re: PERFORMANCE ANALYSIS ( IT HAS BEEN 6 MONTHS ) Actually, I want to write this as my idecad e site. Since October 2017, new projects are almost non-existent. If the size of the project office is micro, it is possible to withstand this crisis for a long time. not. We can say that 95% of the market is micro. 90% of the works that come in these days when we are struggling to stand up are renovations and reinforcement projects. As such, performance analysis and reinforcement analyzes could have kept us alive in this process. I don't know if it's right or wrong, but we had to send all the work we had to them while other offices were doing these things with a different program. Don't get me wrong, but you have condemned us to other programs. That's why it seems normal to me that the program is more widespread. Secondly, you had some responsibilities to us, just as we are obliged to pay the material value you see fit for your labor, but unfortunately you have become one of the reasons that brought us one step closer to extinction in our most difficult day. I wrote this article with the forgiveness of all of you. But in this economic collapse, when one cannot do all three or five jobs at hand, people have to cry out helplessly and with reproach. With greetings and prayers...
The program closes when receiving a report after performance analysis When I want to get a full report after performance analysis, when I click the generate report button, the program closes. Also, when the boost reports tab is clicked, the save and load buttons do not work. I don't think there is a problem with the building model I created. I would be happy if checked.
Re: The program closes while getting a report after performance analysis Hello Performance is not active in this version. İsmail Bey gives information from time to time. Follow the forum. Unver ÖZCAN
Linear performance analysis We want to retrofit the dormitory building. Before the analysis, should we have the analysis done after entering the column reinforcement values obtained from the X-ray results in the building from the program and fixing them from the Ds, or should we leave it to the program itself?
Re: The program closes while receiving a report after performance analysis Hello. It is difficult to follow the forum completely. In the latest version, the performance analysis tab that I see in my program appears to perform analysis when clicked open. When one of the report options is clicked on the room full report option, the program closes. If performance analysis will not be performed, you can deactivate the relevant buttons and add a hint in the help section or in an appropriate place and the subject becomes clear.
Re: Linear performance analysis
"orphans":i6w0von0" said:
Before the analysis, we should have the analysis done after entering the column reinforcement values obtained from the X-ray results in the building from the program and fixing them from the Ds
Yes
Re: Linear performance analysis When will the update including reporting of linear performance analysis and nonliner analysis servers be released?
STRENGTHENING AND PERFORMANCE ANALYSIS AND REPORTING It has been 6 months since the new earthquake regulation was published definitively, it has been 1 year since the draft has been finalized. İdecad should know that it has caused us to lose many customers and jobs.
