Your opinion and suggestion
ATCRMZN
I'm doing İdecad static project drawing for the first time, can you look at my project and comment? When I do it from the ladder drawing command, a blank page appears. I couldn't understand why. Thanks for your solution suggestion..
"ATCRMZN":32qn7m33" said:
I'm doing İdecad static project drawing for the first time, can you look at my project and comment? open?id=0B5xff-sG9-dFNGNGa2p2TVo2cWc]https://drive.google.com/open?id=0B5xff ... 2p2TVo2cWc[/url]
With "Set stair support conditions command" in Stair Utility toolbar Draw the reinforcement axes of the ladder with the command "Draw Reinforced Concrete Calculation Axis for Stairs" in the Stair Utility toolbar. Perform stair analysis.
"ATCRMZN":nrcf8gne" said:
thanks, is there any other problem in the project?
-The floor edge is drawn under the K41 K64 beams on the ground floor. Therefore, the boundaries of the D14 and D16 floors are wrong. In addition, D14 and D16 slabs are defined as single cantilever ribbed slabs with no continuity.
There is an error in the image at the beam junction for the D14 slab, what could I have done? Although it is the same in the other d16 tile, there is no problem, I could not understand
"ATCRMZN":3k4xb93p" said:
I couldn't understand why there is an error in the beam junction for the D14 slab. It's not a problem.There is a small piece of beam at the junction of K62-64 where the D16 slab is.
Define the stair supports with the "Set stair support conditions command" in the Stair Utility toolbar. Draw the reinforcement axes of the ladder with the "Draw Reinforced Concrete Calculation axis" command in the Stairs Utility toolbar. Analyze the stairs.[/quote] GOOD DAY I HAVE PROBLEMS DETERMINING THE STAIR SUPPORT CONDITIONS. ONLY THE SOLUTION OPTIONS ARE OPEN WITH THE STRUCTURE. WHEN I CLICK THEM, NOTHING CHANGE. I TRY TO ASK. THE ROOM IS NOT WORKING. WHAT SHOULD I DO
"solsim":3gdjd4uu" said:
GOOD DAY I HAVE PROBLEM DETERMINING THE STAIR SUPPORT CONDITIONS. THE SOLUTION OPTIONS ARE ON ONLY WITH THE STRUCTURE. WHEN I CLICK THEM, NOTHING CHANGE . Click on any edge you want. The option to solve the ladder independent of the structure will be active. Do the same for each edge to be defined as a support. I did not understand what you mean by "axing". If you ask your question more clearly, we will help you.
