YIGMA BİNA
Hello. Data entry of the panels that you define as masonry on the ground and 1st floor is not suitable for the program. If the panel continues to the upper floor, no beam should be placed on it. Vertical continuity is not provided because you put beams on the wall elements that you entered as a panel object. It can be seen in the perspective window that vertical continuity is not provided in 3D frame mode. Also, this structure looks like reinforced concrete rather than masonry. The system can also be solved by deleting the panels that you define as masonry on the ground and first floor. Good work
