Wood Material Definition
Greetings, I need to do wood structure analysis as homework. But in the program, I see only reinforced concrete and steel in elements such as columns, beams, floors, walls, etc. How can I define column beam wall etc elements as wood, not steel or reinforced concrete? I would be grateful if anyone can help. Best regards
Hello there; In the "materials" section of the build tree, open the right-click menu and click the "Add New Material" command. In the window that opens, select the material type "steel". Change the modulus of elasticity, poisson's ratio, unit weight and thermal expansion coefficients according to the wood material. Then, open the right-click menu in the sections section from the building tree, click the "add new section" command and define the sections to be used in the structure and assign this material to the sections you defined. You can easily read the internal forces and deformations since the elements will work according to the properties of the wood material with the sections you assign the material to. Results for Wood Design alone will not be visible. Best regards...
