Hi Friends, I have window 7 and autocad 2010. Both are 64 bits. I installed both programs without any problems, but when I run idecad on it, it says "HASP KEY NOT FOUND(H0007)". The problem you are facing is because the hasp lock is not recognized. First, check if the lock light is on. And download and install the Sentinel_HASP_Run-time_ setup.zip file from the link below to your computer. If the driver is installed correctly and the lock light is on, the program should run.
If the problem is not resolved, you can contact us by phone 224-2206717 Good luck
