version 6 works very well with windows 7 64 bit. We also recommend windows 7 for version 6 to our users. The problem you wrote indicates a lack of graphics card. Update the video card. You can write more information about your hardware. Are you working on a PC or a laptop? On computers with an onboard display card, the video card is insufficient. For more detailed assistance, please contact us by voice. Good work..."ANCienT":23yf898c" said:I am a user of ideCAD Static 6 (Ver 6.2006) but it does not work on my 64 bit windows7 computer.
I ran the program. 2 program files are created on our computers, 32 bit and 64 bit. the program was loading automatically into program files(x86). I changed the installation location to program files and installed and it started working without any problems. thank you for your attention, good work"HakanŞahin":22ryn3qg" said:6 version works very efficiently with windows 7 64 bit. For version 6, we also recommend windows 7 to our users. The problem you wrote indicates a lack of graphics card. Update the graphics card. You can write more information about your hardware. Are you working on PC or laptop? The video card is insufficient in computers with an onboard display card. For more detailed assistance, please contact us by voice if necessary. Good work..."ANCienT":22ryn3qg" said:I am a user of ideCAD Static 6 (Ver 6.2006), but it does not work on my 64 bit windows7 computer.
The problem is well solved.. But Let me note that there is no such requirement. We work with the program installed in program files(x86)."ANCienT":nar9s6sn" said:was doing the automatic installation of the program into program files(x86). I changed the installation location to program files and it started working fine. Thank you for your attention, good work
I will try again by installing program files (x86) without making any changes on the computer. I will give positive or negative information."HakanŞahin":1hc2lh0y" said:It's good that the problem is solved. But let me note that there is no such obligation. We work with the program installed in program files(x86). .. Your problem must have been solved with another factor..."ANCienT":1hc2lh0y" said:was doing the automatic installation of the program into program files(x86). I changed the installation location to program files and installed and it started working without any problems. Thank you for your interest, good work
