Window Spaces in plan
muhendismy
There are gaps in certain curtains on the basement floor. Afterwards, when we get the basement floor formwork plan, although these gaps are -60 cm below the floor level, the curtain seems to be completely hollow. or as if the plan was taken from the 2/3 level. I can't find a setting for this or how do I fix it?
"muhendismy":2zbi4oet" said:
There are gaps in certain curtains in the basement floor. Afterwards, when we get the basement floor formwork plan, although these gaps are -60 cm below the floor level, the curtain seems completely hollow. I can't find a setting for this or how can I fix it?
Hello; The door and window gaps you define for the curtains are shown on the mold plan regardless of the elevation of the cavity. You can add the cavity dimensions and elevation to the formwork plan using the 2D drawing tools as in the column application plan.
hello, I want to add a window to the curtains in the basement, but it is not possible. I will be glad if you can help me how to work
"feeling86":270wxrhk" said:
hello, I want to add a window to the curtains in the basement but it doesn't work. I would appreciate it if you could help me how to do it
Hello ; You can open a space for the curtains with the door / window command. Switch to architectural plan mode Click on the "Door / Window" command right next to the Axis command, click on the settings in the Toolbar, in the Types Tab in the Settings dialog, select one of the door or window types, enter the information such as width, height and elevation in the Layout tab. Press OK. You can see the preview of the Door/Window when you approach. The value you see on the Toolbar is the offset distance taken from the right, left and middle of the Screen. You can change this distance via the Toolbar. When the Door/Window is in the appropriate position, place it by clicking the left mouse button. Good work.
