Wind and Earthquake Loads-2
mehmet erdogan
To the attention of the İdecad family (Forum members, viewers, officials), it seems that there is an opportunity to enter the wind calculation in 2 different places in 2-İdecad 8: In the Analysis settings, in the Wind Loading section, in the Bide Analysis settings in the Floor parameters section. Which one would be correct to enter these values?
Hello, The two work interactively with each other. You can enter data in both. For example, when you enter the wind load in the analysis settings, you also enter it in the floor parameters. You will see the same values.
