Re: WHY CENTERS OF WEIGHT AND MASS LOOK DIFFERENT Center of Mass: (Xm,Ym) Katin is the center of mass. It is calculated from the mass distribution of the floor. Self-weights, wall loads, moving loads affect the location of the center of mass. Center of gravity : (Xg,Yg) It is the geometric center of the floor calculated from the column and curtain dimensions. Center of stiffness : (Xr,Yr) These are the point coordinates calculated from the column and wall shear forces as a result of horizontal loading. If your structure is the same in terms of both geometry and mass distribution, the center of gravity and center of mass are calculated at the same point. Think of the center of gravity as the geometric center. Design a fully symmetrical structure in terms of column and beam geometries. But let moving loads or wall loads break the symmetry in a corner and get more. While the center of mass of the floor shifts towards that corner, the center of gravity will remain at the center of symmetry. The expression Center of Gravity that appears in the help of the program will be changed to Geometric Center in the next version.
