Why can't I fit the dosemes
Re: help
"mehdiduman":3hbpeo72" said:
why can't I fit the slabs
Hello, K46-beam is not connected to K08 beam, K45 beam is not connected to P07 panel. Activate the "divide by intersections" line in the beam auxiliary toolbar for this.) Other than that, I recommend entering the 30/160 size P07 element as a column object since it does not provide the 1/7 ratio. The joint points of the continuous foundations should coincide on the column and be connected at the joints of the panels. Good work
