While doing static solution
sinan tüten
How can I open the architectural plan (floor architect plan) next to the page we are working on (for example, the ground floor ceiling) while making static calculations. Seeing the architectural floor plan next to the static plan at the same time while doing static calculations will bring great work comfort. I would be happy if you give the necessary information.. I wish you good work. .
Hello, You can convert the architectural plans into a two-dimensional drawing file and place them in any window using the Copy/Paste commands. If you have the architectural plan as a dwg file, you can import the drawing with the Project/import/dwg command. Good work
"sinan tüten":9zr2z1uz" said:
how can I open the architectural plan (floor architect plan) next to the page we are working on (for example, the ground floor ceiling) while calculating. I will be happy if you give me the necessary information.. I wish you a good work.
I don't know why you needed this. Apart from what Levent said, if you are working on a project prepared by IdeMimar, the program "Settings / visibility of objects on floors[/ It has a command like u]". It shows both existing floor, both downstairs and top floor, moreover, different in static or architectural mode. However, you should not paint the inside of the tiles you create.
P27 and p29 curtain length is less than 7 l of curtain thickness, what kind of solution would you suggest.. I would appreciate your help.
"XELLO":11ppv3ev" said:
What kind of solution would you suggest if the p27 and p29 curtain length is less than 7 l of the curtain thickness.. I would appreciate your help
Ignore this warning given in the geometry control because it is an earth curtain. It will not show as an error in the reports. .
