Which is the most important to shorten Analysis Time?
sereze
Which is the most important to shorten the analysis time? Processor Speed Graphics Processor Speed Graphics Processor's Memory RAM How do they affect? I'll buy a computer for him. Thanks
Re: Analysis Time The speed of the graphics processor or the amount of memory has no effect on the analysis time. If the system memory is sufficient for analysis, a faster processor (more memory will not have much effect if the memory is enough, but if it is not enough, you will encounter excessively long analysis times or you may not be able to analyze at all), if not, more RAM and faster processor will allow you to get results faster.
Re: Analysis Period HELLO.. THE ANALYSIS PERIOD WAS TOO LONG AFTER THE LAST UPDATE OF IDECAD IS COMING, I WOULD LIKE TO HELP. MY COMPUTER SYSTEM WIN10 PRO-64 BIT INTEL İ-7 7700 HQ 2.8 GHZ 8 GB MSI GV72 7RD
Re: Analysis Time
"enesss":2rme9cvg" said:
HELLO .. THE ANALYSIS TIME HAS BEEN TOO LONG AFTER THE LAST UPDATE OF IDECAD I'M GOOD HELP. 2.8 GHZ 8 GB MSI GV72 7RD
By the last update, do you mean after the switch from v8 to v10? Then it is very normal that the analysis time is extended. The number of analyzes has increased a lot. If you mean after an interim update in v10, how much analysis time for the same model in which version? Please write that.
First of all, thank you for your interest. After Idecad upgraded from v10-16 to v10-17, it took a long time and sometimes it took 20 minutes from time to time. Thanks. Sent via iPhone using Tapatalk
Hello, The ladder is not supported correctly, so the analysis time is longer. (7.17 minutes on my computer) When you delete the ladder on all floors, the analysis time decreases. (6.51min). When you select Static eccentricity in the analysis settings, the time becomes 2.5 minutes. Finally, this structure is not necessarily a semi-rigid solution. Therefore, if the rigid diaphragm solution is marked and static eccentricity is selected, the time analysis time decreases from 7 minutes to 28 seconds on my machine Mathematical model of the Slabs as Semi-rigid (Shell) decreases the analysis time. affects selection. It then affects the dynamic eccentricity. Later, the presence of basement floors in the building affects it. As the curtain and floor finite element sizes get smaller, the analysis time gets longer.
