In case of selecting the "Beamless Slab(Mushroom)" option on the slab type page of the TBDY Analysis settings wizard in systems with beamless slabs, item 4.3.4.4 is automatically applied in the program. General information of construction - The Loads and Combinations report lists the combinations where the columns are hinged and therefore the earthquake effects are met by the walls."acgyapi":27i6txbk" said:Good work guys.According to TBDY 2018 4.3.4.4 article, all the earthquake effects in beamless floors must be covered by the shears. Where and how can we check whether the condition is met in the program or in the calculation reports.
Hello; Definitely do not make such a solution, this and similar approaches are solutions against the regulation. In the capacity design approach, the capacity calculation of individual curtains and the capacity calculation of group curtains are made according to different approaches. In case of insufficient capacity, you can reduce the capacity ratio below 1 by manually increasing the group curtain reinforcements. It is our expectation from the building that the design of curtains and other elements can be made automatically in the following versions, taking into account the capacities. As a suggestion, if you are not using it, use V10.17, it contains improvements in this regard. Best regards. Sent via iPhone using Tapatalk"unver":6zxryrv1" said:HiThis kind of error in RERDE GROUP BEND DESIGN when you group curtains If so, untie the curtains without grouping The proposed project is attached. Unver ÖZCAN"acgyapi":6zxryrv1" said:Do you also have any advice about the project?
Hello The reason I am writing this suggestion: In some projects, the program gives such an error when the group curtains. I first reported a project similar to this situation to Mr. İsmail Hakkı BESLER. He explained the situation to R&D. When I gave C30 in the project I reported, it gave an error like here. We can't use C20, but I wrote it for you to see the situation.) My aim here is to find a solution to the project Ünver ÖZCAN NOTE: After this stage, I am waiting for comments from IdeCAD officials on what to do about this issue."unver":3au4olra" said:If there is such an error in the RERDE GROUP BEND DESIGN when you group the curtains, solve the curtains without grouping them.
Thank you İsmail Bey"Ismail Hakki Besler":1r70g5c6" said:Do not solve separately, definitely solve the polygon Reducing the concrete strength is only about the minimum reinforcement. Do not reduce the concrete quality Do not reduce the concrete quality Enlarge the curtain cap areas Increase the reinforcement area in the header area
"Ismail Hakki Besler":3gecgxg5" said:Do not solve separately, definitely solve polygons /quote] Thanks İsmail Bey, when he used the amount of reinforcement in the basement and the length of the headboard, it decreased below 1.
[quote ="acgyapi":7vmxpb5r"]Thank you very much Mr. Hakan... I still can't do it. [/quote] You can do it if you follow the steps below. 1. Open your project whose link you have given. (İdestatic Subasman1.cde)"acgyapi":7vmxpb5r" said:Hello Mr.Hakan... It didn't work even though I did what you said in the project I posted below. In the project I changed, the floor tiles were three pieces. In the project I shared on the forum before, the floors were five pieces. It would be greatly appreciated if you would add and send the basement curtains to the project.Thanks...You do not have permission to view link Log in or register now.
