Polygon columns You can change their dimensions with the column trim method. You can use Axis, Beam or ideCAD Architectural walls as a reference while trimming. When you want to change the dimensions of the columns, -On the plan or perspective screen, -Select the columns from the column properties -After selecting the columns, with the Change Column Dimensions command in the left vertical toolbar -Reinforced Concrete menu in the Column dialog B. and H values. Pitches have two nodes. You can change these nodes by moving them. -Select the pitch, click and move the joint point -You can use the Move Node command in the upper toolbar. You can quickly select multiple nodes you can carry."fuatturan":b1gsk8ui" said:I will be glad if you can help us to change the dimensions of polygons and columns and curtains, thanks.
