When you export DWG, everything is in the "Standard" Layer.
mulugol
Hello... I'm a fresh IdeStatik 7 user. At first, I was exporting all the drawings one by one as DWG. However, it was very difficult for Autocad to deal with pen thicknesses. Now I make all the drawings one by one as a block, arrange them side by side on the Layout I created and export a single DWG. This way, I don't bother with pen thicknesses, because he takes care of everything himself. However, this time, since everything is on the "Standard" layer in the drawing, I cannot select some things I want. For example, I need to select and delete Reinforcements and Reinforcement Texts in order to make a "Die Dimension Plan", but this is not possible because everything is in the "Standard" layer. How do you do this? Which is easier? Thank you in advance for your answers. Good work...
AutoCAD is not needed when working with IDE Programs. All drawing, layout and output operations are taken over ideStatic Architecture etc. With the help of the ideWrep file, those who make drawings can also do the output process easily and free of charge without the need for a license. In this sense, there is no need for any other CAD program from calculation to drawings, from drawings to preparation of sheets, to preparing sheets and taking printouts. You will not encounter the problem of pen thicknesses since all operations can be done easily on the ide. If you want to make specific formwork dimensioning (i.e. only formwork plan drawing without reinforcements). After you have drawn the formwork plan, you can copy and delete the already block reinforcements with one click. Creating a dwg and opening it with AutoCAD can only be used to send the project to a third party that does not have an ide program and for review. (Municipalities or building control etc.)
Thank you for your interest. I did as you said. It was number 10. Now my problem is this: As you said, I need to add a letterhead and site plan to the beginning of the drawing so that there is no need for another program. First of all, I tried to add the standard letterhead we use in Autocad. The text comes out, but there are no lines forming the letterhead. I played with colors and tried different combinations in Antette Autocad. I even made the lines "White", "Black", "Red", I tried the Color "ByLayer" etc etc, but in vain. It does not appear in the output. Only texts appear. I would be very grateful if you could tell me about it too :)
Import the dwg file, which is the title file, into idecad. Check the Use closest colors option. This way it should run smoothly. You can place the letterhead inside the ide drawing and then convert it to dwg if necessary. If not, draw the letterhead in ideCAD for once. Then save it somewhere on your computer with the copy to file command (with .blk extension). You can call and use it with the paste command from the file in the project you want at any time. There is also a title creation section in ideCAD. You can also use this. You can bring it ready-made through the template project. If not, share your letterhead, I'll edit it and send it to you as a block. Good work. N. YILMAZ
Thank you again for your interest and support. I'm importing as you said. I tick the "Convert to closest colors" option. However, only texts appear. When I try to import it to any floor plan and try to print it out, the lines appear in the output, but when I import it to the Layout I created, the lines appear on the screen, but they do not appear in the output. Interestingly, the title letter I created with different colored lines in the Layout is not in the output either :) Blocking and undoing it doesn't work either :) I couldn't find the title section in IdeCad 7. I'm guessing maybe you're talking about 8. Finally, there is a problem that I think is caused by the old age of the computer. (Q9300 processor, 4GB RAM). Ide's print preview screen constantly drops to "Not Responding". The first 4-5 meters of a 40-meter drawing are formed, going back, coming back, going back....... Even though I waited for minutes, I couldn't see the preview of the whole drawing. Also, the zoom event in the preview is not very useful. Old version is available as it is licensed by Autocad. So I can see the preview of 40 meter drawings very comfortably. RESULT: Mold Dimension Plan was perfect. Thank you very much for that. However, it seems to me that for the outputs I will have to continue with the old system again. Thank you again for your interest and support. Good work, regards...
Hello, if you add the project that you say "not responding in print preview", we will review it. Also, if you add the dwg that you say "Convert to closest colors option. However, only texts appear", we will help you examine it.
I couldn't add it here because of file sizes. I am providing the Google Drive link. Ide File:
Title File: [url =https://drive.google.com/open?id=1hrn5bZQq6hVVzyP_NO6oMBnzq-gl-aO8]https://drive.google.com/open?id=1hrn5b ... nzq-gl-aO8[/url] Header file It was all white before. I've turned the lines blue to see if that's why. I am sending it this way. Good work...
Your letterhead file has been improted without any problems. Illustrations and inscriptions appear seamlessly. And I have improted it into your file, there is no problem.
It appears on the layout screen. Can you see it in print preview? Or are there lines in the output? By the way, which version are you using?
Since you said V7, I'm looking at V7. Since the color of the text is white, it naturally does not appear white in the print preview background. If you change the text colors or check the draw all colors as black option, they will also appear in the preview.
The "Print All Colors Black" option is already selected. So I can see the texts in the print preview. But as I said, when I import the file to any floor plan, everything is in print preview, but when I import it to Layout, the lines are not in print preview :) I think there is a problem with my computer. I'm tired of you too because of my own problem. Get your right.
By the way, I took the letterhead next to any curtain detail. How they will look side by side in print preview. For the output area, I have determined a tiny area consisting of only a single screen detail and letterhead. Curtain detail comes and goes every 2-3 seconds. This keeps repeating. Could it be something with the video card or opengl? Video card ATI Radeon HD 3850
I don't know how I did it, but I recreated a layout and got the letterhead visible. The letterhead now appears in print preview. However, even in a print preview with only "letterhead, basic application and basic beam expansions", drawings are made halfway, wiped back, half done again, wiped back to the beginning... etc... etc... It goes on forever. Even a preview of a 2.50 meter sheet is like this. Thank you in advance for your interest.
