When modeling a single-storey building, are the basement curtains separate floors
burakerkişi
-When modeling a single-storey building, should it be modeled as a separate floor, or would it be a more accurate modeling to model a single floor and adjust the height of the basement curtain? - In the sub-basement curtain project output, curtain shoots and curtain vertical reinforcements are drawn separately, so it adds extra overlap length. Since these curtains are generally short curtains, they can basically be applied in one go. Is there an option where we can print these accessories in a U shape? Or can it be created? Is this app correct? Thanks.
Re: ABOUT THE MODELING OF SUB-BASE CURTAIN IN A SINGLE-STORY BUILDING
"burakerkisi":dk1aj6r1" said:
-While modeling a single-storey building, should the basement curtains be modeled as a separate layer, or modeling a single storey and adjusting the height of the basement curtain? Would it be a better modeling?
Hello, -You can model by adding the sub-basement curtain height to the floor height.
- In the sub-basement curtain project output, curtain shoots and curtain vertical reinforcements are drawn separately, so it adds extra overlap length. Since these curtains are generally short curtains, they can basically be applied in one go. Is there an option that we can print out in a U shape? If not, can it be created? Is this application correct? You can edit two dimensions using the drawing facilities. Good work
